I found an abandoned epson 9000i and had a similar problem. The fan was corroded and would not...
(More)
I found an abandoned epson 9000i and had a similar problem. The fan was corroded and would not turn. Check to see if your fan is running or not. I'm trying to figure out if putting a new fan on it will fix the problem. I would like to figure this out without spending money on a new epson fan. Is there any way to jump it for a test mode? Will any cpu cooler fan I put on there work?
Have been told by the supplier the thermal cut out switch is creating a problem after a new lamp has...
(More)
Have been told by the supplier the thermal cut out switch is creating a problem after a new lamp has been fitted. The thermal cut out can be repaired easily according to the supplier. Please advise on repair to this switch . Thanks.
