Question about Ovens
Westinghouse 745 wall oven
Hi, my oven seems to have a mind of its own and only starts when it wants to. i am not sure as to if i am setting a timer or not but i need help. as i amm looking forward to one of my wifes roasts! I've had the same problem since losing power in a storm. There are 6 buttons to press but none say "reset clock" or "manual cook". Desperate pressing eventually gets it going but we cant work out the code!! Then the timer goes off in the early hours and the next time we want to use the oven it's the same story! Driving us nuts!! Need help Westinghouse 745 fan forced gas oven
    Scholar:
  • 68 Answers
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Posted on Nov 11, 2008
My Westinghouse 668 wall oven won't allow me to set the time. We had a power outage and I have checked the power and it's fine now. But the display flashes between 0:00 and auto and I can't hold the two...
Does the rest of the oven work ok? Did the timer work OK before the outage? Is the oven under warranty? Was the power outage at your home only? Check with the manual to see if it addresses your problem, there may be a way to reset the system and then I would say that you would need to contact Westinghouse and explain the situation.
Nov 06, 2014 | Ovens
Need Westinghouse gas wall oven AWGB700FP manual
Request the manual directly from Westinghouse.
Jul 20, 2014 | Ovens
Hi i am looking for a manual for my wall oven its a Westinghouse wall oven POPS668S
Here is a direct link to download your manual (free). This manual covers several similar models including yours:
http://manuals.appliancesonline.com.au/westinghouse-electric-wall-ovens/westinghouse_electric_wall_ovens_manual.pdf
Click the link and the file will open and you can then view, save and/or print the manual. You need adobe reader to view the file which can be downloaded here if the file doesn't open:
http://www.adobe.com
Please rate this solution if you find it helpful. Thanks.
Oct 17, 2010 | Ovens
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
278.4088891 Kenmore wall oven. The display goes black
Hi
Sounds like the "display" part of the timer is faulty or has a bad connection. As the cooker still heats up then the "relay" is working ok.
A replacement timer will be roughly £70 - £80
Hope this helps
Aardvark Repairs
Nov 15, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
I have just moved into our new home with a Westinghouse wall oven. The previous owners have scrubbed the model number paper tag off so I can't give you that details. The left knob is labelled Function the...
Go online and type in westinghouse ovens/stoves that looks similar to yours and look for one with dig readout. Then type in that model # then manual on a Google search and see what pops up. I'm sure that most if not all of them are then same for setting time..
Oct 06, 2009 | Ovens
Delay or time bake
You can find the manual at www.managemyhome.com, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Jan 30, 2009 | Kenmore 47772/47774/47779 Electric Double...
HBL 745 - stopped working
seems the oven was locked by the kids by mistake - found the manual and unlocked it.
Oct 14, 2008 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
734 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
