My Panasonic machine has been producing excellent loaves on automatic for some time. The last time I used it , the machine did not knead the dough but baked it anyway.You can guess the result!. It kneads the dough on the pizza setting ok and will then bake if I switch to Bake. It sounds like a programmer error.It started with the prog. window saying'Reset'. This has now disappeared, with the display back to normal, but left me with the foregoing problem. Any ideas?.
The only thing you can do for these machines is the following:
first, if the unit is always plugged in, disconnect it for at least an hour. This may reset it.
I doubt there are parts...but if you disassemble the unit and cycle all of the connectors, you may get lucky. IF parts exist, you'll likely need a timer module.
This was my first post and am delighted to report that your suggestion seems to have cured the problem!. The machine is going through a dummy run ( no ingredients) and has just successfully performed the mixing stage, the bit that was malfunctioning before. Fingers crossed it should be ok now. Grateful thanks to Bob from LI. Know where to come with my probs in future!.
