Question about Sharp AR-5320 Black and White Copier
When I photostat, items repeat one page
When I photostat, items repeat in the copied page
    Problem Solver:
  • 11 Answers
Replace the drum and cleaning blade,also check that the fusing roller is clean.
Posted on Nov 28, 2008
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
System Error E007
Its a fixing film error, it means that fixing folie is worn out.If you do not want to change fixing heater you may try to buy Katun film only, but it isn long term solution.
Try to turn of and on and you may get few more copies.
If you have over 500 000 copies change the whole fixing unit
Feb 25, 2010 | Canon iR 2016i Black and White Copier
Blown head gasket on a 1997 ford taraus a diagram
if u live by a library go to their reference area and look up their car repair manuals photostat the 3 pages if library is neg ask an auto shop if u can copy theirs ,or go 2 a police dept that has the mech shop on grounds they have the books and cd s for the ford line. or last chilton or haynes books
Sep 25, 2009 | 1997 Ford Taurus
How can I fix the drvstre file?
If your asking how do I Copy and Paste ... several keyboard commands exist to help with this method. I call it a Method because you are asking the program to do a task, this case copy and paste. And of coarse a User can still use the Mouse to Copy and Paste. Both Methods will be described.
The [Ctrl] control button on the key board will allow the user to cut and paste what they want. These are considered keyboard shortcuts.
Step one: select the object(s), by highlighting it with the mouse. Right click and drag the mouse over the desired item(s). Or if the entire page needs to be copied, Ctrl + A will select everything on the page once the curser is placed at beginning of the page.
Step two: Once the user has selected what they want, depending on the function they performed for the selection, ( by right-clicking the mouse and dragging over item(s) ) the user now selects Copy ( makes a copy of the selected item ) or Cut ( removes the item from the original page ) from the drop-down message, and prepairs to Paste the selection to the new page or position ... keep in mind, Ctrl + C will copy the highlighted item as well.
Step three: to paste the item on new page, user left-clicks the point were they expect the item to be placed. And again, depending on the function called upon, will right-click and select Paste from the drop down box. Or press the Ctrl + V buttons. The selected item will appear at the point were the curser is flashing.
Helpful hint about [Ctrl] methods. Ctrl + X will delete the selected item, Ctrl + Z will undo prior editing steps. [Ctrl] methods are quick, easy functions, that allow the user to become productive. I recommend that the [Ctrl] method be emploted whenever possible. I hope you enjoy. Have fun.
Aug 13, 2009 | Microsoft Windows XP Home Edition
Sir, We had purchased a Photostat mechine Toshiba E-studio 200 on 27-08-2005 from M/S HCL INFINET LIMITED XL/8794,MG ROAD,COCHIN-35 and Annual Maintenance Contract was being executed with the above firm...
The "Processing Unit" is a consumable item. It is a cartridge that has the OPC drum and developer in it... It is only good for "X" amout of copies and it will need to be replaced..Good Luck
Apr 25, 2009 | Toshiba Office Equipment & Supplies
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Jul 12, 2008 | Office Equipment & Supplies
Instruction Book Needed
Go here: http://www.creda.com/macro/header.d2w/HomeStart
Dec 28, 2007 | Heating & Cooling
Colored bars across page
I would try changing the ink cartridges and if you don't have a new set at least take out the ones you have and reseat. Also check Epson's site for new drivers. Try printing from a different program.
Mar 28, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Sharp AR-5320 Black and White Copier Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
