Washer fills and then goes dead. we have replaced the lid switch and drain pump. trying to see what next or if we need to replace a washer.
SOURCE: Washer doesn't spin or drain unless I open the lid.
hay this is a tougher one .i tried to find a wiring diagram but couldn't.so ill tellyou what im thinking.when it stops and you lift the lid and it gets going is the clue,we know motor ok it will spin .we know lid switch ok you replaced.sooooooooo take a look at your diagram and see what componets come into play by way of the lid swtch opening then closeing.some how power is diverting may be to timer..........wow you gave a pretty good report on whats going on.so im reading and the running it in my mind.you say it will agaitate until in off position.so im thinking how can that happen.there has tobe a contact point stuck.when unit gets to end of washs cycle it should pause and wait to empty then refill or spin if after rinse .the presure switch tells the timer that has been done,but if presure switch bad washer may over flow or not fill so it seams fine.thinking.......you could use the process of elimanation but that could be expensive.thinking.........could the presure switch hose be blocked ,fooling the system? clean blow out.there can be no water in it before the tub fills..........you can blow thru tube while attached to presure switch and with ohm meter make sure its switches are working........but check all you can to elimanate the eazy stuff and go from their.i hope ive been some help.you can email if any questions .God bless ,tom
SOURCE: Whirlpool top loading washer will not spin or
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
SOURCE: Kenmore 600 series top load washer fills with
It sounds like you may have a broken motor coupling. Failure to agitate or spin accompanied by the sound of the motor running with no tub action are some of the symptoms you can experience with this problem. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If you determine the coupler to be defective, the next link explains how to access the coupler and replace it:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is commonly sold as part of their in-store inventory. The average cost of a motor coupling is about $15.
If you have any questions, please post back and let me know. I hope this helps you.
SOURCE: my ge wsm2700dawww stack washer will not agitate or spin
Hi
Please find the links bellow to diagnose your problem…since your problem to the washing machine can be caused due to various reasons.Please go through the article to have an in-depth knowledge to your query…
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntspin
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntagitate
http://www.geappliances.com/search/fast/infobase/10002166.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
