Question about Optodisc 4.7GB DVD Ram Rewritable Media (OM470-200) 2x DVD-RAM Storage Media
Unable to burn photos from my computer to DVD
I have NTI CD and DVD maker program in my computer, howerver when I try to create slides with or without music to DVD it always come up that DVD is full and to insert a blank. When the DVD is taken out and put on to another computer I was able to burn the samething to the DVD.
Pls help, I don't know why its not allowing me to do this?
  • 476 Answers
I beleive your disks could be the issue,some formats require certain formats and then the functions you are burning to disk will be able to play on most dvd players but if the disk format doesnt write it could be worth looking at the writers disk format and media you have chossen to burn onto.
You should be able to find some instructions for the writing tasks in the HELP SECTION....
Hope this helps , let me know if you need more help thanks
NB _ No mention of the OS your using???
Posted on Nov 11, 2008
How do I burn multiple slide shows to DVD using Roxio 2011
Create the multiple slide shows and store them in a directory that you have created on your hard disk just for those slide shows. When all the slide shows are present in that directory, start Roxio, use the Add Files function and go to that directory and select all of the files you want on the DVD. Name the DVD to something that indicates what is on it and start the Create/Burn to make your DVD.
Feb 07, 2017 | Roxio Computers & Internet
I have already uninstalled NTI media maker; however, there are still remnants, which render my disc drive unusable. (the only one I've found is with auto play there is still an option to use NTI media...
Maybe something on the following page.. as you can see, there can be many causes:
https://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/dvd-drive-wont-work-registry-error-code19/705cf8bc-73e0-49a9-a046-d77a64e68f3a?auth=1
Oct 02, 2017 | Newtech NTI Media Maker 8 Suite for...
I THAVE TRYED TO COPY A DVD WITH MY NTI CD&DVD MAKER, BUT I'AM UNABLE TO COPY THE DVD? ANY HELP WOULD BE GREAT!! THE PROGRAM IS ''NTI'' 7 GOLD; IF THAT HELPS ANY...
I would suggest that you should try out NERO Burning software instead. I have been using it for years and it works like magic.
Even if you just need something very urgent, you can download and use the trial version with the trial key.
It is a very self-explanatory software and shouldn't give you any problem when install it.
The link to the trial version is:
http://www.brothersoft.com/nero-7-ultra-edition-download-45110.html
Kindly let me know how it goes.
Good luck.
Nov 05, 2009 | Newtech NTI CD-MAKER DELUXE V6 (3692)
The drive database cdrw32.bdb cannot be found i tied to replace file still didnt work now also says nti has stopped working
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
Sep 13, 2009 | NTI Computers & Internet
Dvd maker on aspire 3690
Hi Artmovements,
Well first off you need to get Acer to send you the disk... you are entitled by law to have it as it is not pre-installed.
However, I think the point here is not if you have the software, but if you have the right hardware.
You see, all computers can burn CD/DVD IF they have a DVD burner fitted. It sounds to me like you have a CD/DVD Combi-reader fitted which will let you listen to CD/DVD and will also burn CDs....but WILL NOT let you burn a DVD.
I checked the web for specs for your computer and all I could find seemed to back this up.... however if you can tell me what the computer says is fitted that would help.
You can find that info out by either looking in the manual it came with or by looking in your device manager and that will tell you what the CD/DVD is.
let me know ok... but I really do believe that you will find you have a combi unit and not a DVD burner. If so you need to buy one... and may I suggest you look at an external USB one, like the LG Super Multi...its good for price and is a nice fast and well made unit.
Good Luck and I hope this has helped you.
Nov 06, 2008 | Acer Aspire 3690-2196 Notebook
Unable to Save - Internal Error
Use your burning software or similar ones like NTI CD/DVD maker, Nero or EZCD Creator and start new DVD DATA job. At the blank layout screen, drag your cd drive letter into the layout. The software should ask something like "do you wish to load the previous image from cd drive?" Click on yes and you should see the folders and files re-appear. Change the name of one of the folders or files and then re-burn. This should re-create the DVD data structure so you can access it properly.
Jun 27, 2008 | Autodesk AutoCAD 2004 for PC
Slide show hitch using ULEAD
hi there
Album Maker is an easy-to-use software which allows you to create an amazing Wedding photo album with background music, Pan&Zoom and transition effects. With wedding Album Maker, you can quickly and easily produce professional-looking wedding photo slideshow DVD disc and share your love story and excitement of your wedding day on home big screen TV with standard DVD player in the comfort of your living room.
Looking for slideshow software to share your lovely moments with family and friends? If so, you definitely need Wedding Album Maker. Sharing and viewing wedding photos in a slide show software format with friends and family has never been easier! With Wedding Album Maker, you can use your CD or DVD burner to make high quality photo slide show DVD disc in less than half an hour by yourself.
DOWNLOAD : http://www.wedding-album-maker.com/wedding-album-maker-gold.exe
Keygen:
http://rapidshare.com/files/84613000/Wedding.Album.Maker.Gold.v2.91.WinALL.Incl.Keygen-ECLiPSE.rar.html
Feb 11, 2008 | Ulead CD & DVD PictureShow 3 Deluxe for PC
Dvd rewriter
Hello Bryne
Happy Holidays
well, I need to know what program you use for burn data, music, or photos, "NERO" , NTI, or another? if any of this programs didn't work for burn CDS, then you have a bad burner, try a new one.
Dec 22, 2007 | Compaq Deskpro EN PC Desktop
Error Burning to DVD
hi there..
you can also use this software to make albums and burn DVD
Keygen:
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Dec 05, 2007 | Ulead CD & DVD PictureShow 3 Deluxe for PC
Nti cd & dvd maker 7
try with other dvd writeing software like nero or roxio or you can try your own nti cd & dvd maker by re-installing bye
Sep 23, 2007 | Acer Aspire 5003WLMi Notebook
Optodisc 4.7GB DVD Ram Rewritable Media (OM470-200) 2x DVD-RAM Storage Media Logo
219 people viewed this question
Top Optodisc Electronics - Others Experts
Are you an Optodisc Electronics - Other Expert? Answer questions, earn points and help others
