Question about HP Jetdirect 170x Print Server
Flashing status light
Basically, my documents won't print but the status light is flashing. Anyone know what this means?
  • jameswills Dec 01, 2008
    I think the print server is dead!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Yes, it could mean one of the following possibilities:
Encountering one of the following conditions:
  • running a self-test
  • not configured.
  • not able to attach to the network.
I am putting money on a bad cable/connection, check your network cable.
Hope this helps.
Posted on Jan 11, 2009
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
Nov 20, 2017 | The Office Equipment & Supplies
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
Jun 27, 2014 | HP OfficeJet Office Equipment & Supplies
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
The light on the right is flashing red.
d40a83b.jpgCancel button
0de392d.jpgPrint cartridge status light
84e6616.jpgResume button and light
e1e1095.jpgPower button and light
- If the power light is flashing it means that your printer may be receiving data.
- If the resume light is flashing you may be out of paper, or you may have a paper jam, you may be printing a two sided document by hand and the first side has finished printing.
- If the print cartridge status light is flashing that means the top cover may be open, of there may be a problem with one of the cartridges.
- If all of the lights are flashing the printer may need to be reset.
Hope this helps.
Jan 06, 2010 | HP DeskJet 932c InkJet Printer
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
My ip3000 status says "collecting printer status". I have checked the cords and turned it off and back on. Still won't print. Thanks.
If lights are flashing on the printer, I need to know how many flashes to know what to do. Unless the printer is on and with a ready light, you won't be able to print or collect status.
Aug 12, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
GREEN LIGHT KEEPS FLASHING ON MY PRINTER
Green light flashing means printer is in printing process. No problem. If you want to stop printing. delete printing job from printer properties or stop printing from status monitor.
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Hp deskjet 960c
You say it stopped working mid-print... possible paper jam? Ink cartridge not clicked in all the way? (they should all line up evenly across the tops).
In control panel->printers and faxes, right click on Canoni960 and choose properties. In maintenance tab try to do nozzle check and print head alignment. In lower right corner is status monitor, click to see if any useful information in there.
May 17, 2008 | HP DeskJet 960c InkJet Printer
Printing Dillema
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
HP Jetdirect 170x Print Server Logo
1,950 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
