Question about Intel Motherboard
How to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
I cant seem to figyre out the connectors for the front panel like sound , mic and usb cables to motherboard .please help .
    Master:
  • 763 Answers
From your case there are wires to put it on the motherboards pin. you can check your motherboard's manual on where to insert the designated wires to the correct pins.
thank you for using fixya
CHARCOIS
Posted on Nov 10, 2008
  • 599 Answers
Look in manual for the computer case ..will identify which cables are for which front panel source..then in manual (online or paper) you route to your motherboard for USB/sound etc.... good luck
2 Suggested Answers
  • 154 Answers
SOURCE: gigabyte motherboard connection front panel to motherboard?
Have you reseated them properly? Did you have the power connected still when you took them out and put them back in? If you had power still plugged in you have probably fried the ports.
Posted on Jul 26, 2008
I have gigabyte ga-g41mt-s2p mobo does anyone have picture of correct cable connection layout, so I can check visually if I have connected the cables correctly
You can download "GA-G41MT-S2P" Manual and all the cable connections are in the Manual.
FYI
As for the Front Panel ATX casing cables connections, the "white" cables are the -ve polarity & the "coloured" cables are the +ve polarity.
Hope it helps.
Jun 26, 2011 | Gigabyte GAG41MTS2P motherboard
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
How to connect front usb and audio cable on gigabyte mother board
The USB pinout on all motherboards is as follows >>>>>>
As for the audio you can visit Gigabyte's support website for the schematics for the front audio.
Regards.
May 24, 2010 | Gigabyte GA-8I865GME-775 Motherboard
GA-8S650GXM FOR USB FRONT AUDIO PANEL
You will need the motherboards manual to help you with connecting USB_1, USB_2 and F_PANEL audio to you're case. If you do not have you're manual for the GA-8S650GXM you can download it from Gigabyte; http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s650gxm_series_e.pdf
You will also need Adobe reader installed to view the manual.
Gigabyte GA-8S650GXM main web site; http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1658
Turn to page 18. Number 17, F_USB1/F_USB2. Use the link provided below to help you connect you're front case USB wires to the motherboard; http://www.directron.com/installusb.html
Turn to page 24, for front audio connections. Keep in mind once you configure you're audio to function from you're cases front audio port you will not be able to use the rear audio port. Caution, most people find bumping any front case USB or audio cords break far too easely. To avoid breaking the front audio port, consider using a Y splitter for the rear audio port as shown in the next link; http://shopping.yahoo.com/p:StarTech.com%20MUY1MFF%20Audio%20Video%20Cable:1991733360;_ylt=Ah94ikZN9zDbTi2.arc45BkbFt0A
Hope you find this helpful.
Mike
Jan 22, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Schemat audio front panel conekt
Here is the link for the manual. It will show the jumpers and pins for sending to the back and front. USB, sound, etc.
http://english.gigabyte.ru/products/mb/manual/ga-ma69vm-s2_10.html
Good Luck
Dec 17, 2009 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
Would like to find the pin sequence for the
black green white red inside row nearest battery,starting from the front facing end.
Mar 13, 2009 | Gigabyte GA-8SIML Motherboard
Gigabyte motherboard driver
The problem is not with *********** Board. Check the front panel audio connectors inside your CPU are connected to *********** Board properly.
Sep 28, 2008 | Gigabyte GA-N680SLI-DQ6 Motherboard
No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Mar 14, 2008 | Computers & Internet
Intel Motherboard Logo
1,265 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
