Question about HP Pavilion dv6000z Notebook
My computer cant start up and is making a beeping noise
I have an HP pavilion dv6245eu. it runs on windows vista premium. it switches on, but my screen is blank and there is no activity except for a beeping sound. its two loud beeps. i have stuff that i recently put on there and havent backed up. is there anyway to fix it without losing my information?
  • 2 more comments
  • nickmenaris Jan 14, 2009
    I have a similar problem with my HP Pavilion A1410E desktop. I would appreciate any advice on whether the solution described here has worked.
    Nick
  • martinam Feb 08, 2009
    I have the same problem with notebook pavilion dv6000.I tried to remove the memory boards and put them back again,but it didn't help.Last time I started it the problem to start was reported,but the computer was not able to specify the cause of the problem and fix it.Since then,I've never got it started again.
    Thanks for any suggestions.
    Martina
  • Anonymous Apr 09, 2009
    My computer is doing the same thing, except after making the noise I can turn it on, but it takes me forever to figure it out because it always messes up.
  • Anonymous May 04, 2009
    I had the same problem. Just reset the ram board. Take it out put it back in and the beeping noise is gone and then the computer will work fine. I had to do this several times.
    President:
  • HP Master
  • 1,314 Answers
Most likely a ram problem. Sometimes reseating the memory will fix the problem.
Remove and reseat the RAM On most notebook PCs, removing and reinserting the memory is a simple step and does not require advanced technical knowledge of the computer. HP recommends reseating the memory module before arranging for warranty service repair. If you are not confident following the steps for removing and replacing the memory module in this document, contact an HP support specialist for assistance.
NOTE: If someone other than HP installs or upgrades the RAM, any damage caused by the RAM and/or by the person when trying to install or upgrade the RAM is excluded from coverage under the product warranty. The customer assumes all risk and liability for damages for any such installation or upgrade.Some HP notebooks may have a secondary memory module located under the keyboard. For removal and replacement instructions pertaining to the second memory module contact an HP support specialist for assistance. WARNING: This product contains components that are easily damaged by Electrostatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, set the notebook on a grounded surface that dissipates any static charge, and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC. Use the following steps to remove and replace the memory modules. These steps should be repeated for each memory module installed in your notebook. Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
    NOTE: When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. After removing one module, replace the memory expansion cover and then replace the screw.
Step 3 - Reseat the memory module
  3. Locate the alignment slot on the memory module and align it to the empty board receptacle.
  4. Grasp the memory module by the edge and push gently to install it.
  5. Press the expansion memory board down to latch the tabs.
  6. After replacing the module, replace the memory expansion cover and then replace the screw.
After the memory is reseated, connect the AC adapter and turn on the notebook.
Posted on Nov 10, 2008
    Problem Solver:
  • 4 Answers
It could be RAM. Try switching the RAM. Most computers have two RAM modules. Try trading places with the two. If that brings it almost to life, one module is bad. Look online and buy a cheap memory module. Don't buy from Eagle memory. The guy sells junk and doesn't give refunds.
Posted on Sep 10, 2012
Hp pavilion beep
Try setting the AHCI to SATA in the BIOS.
May 10, 2012 | HP Pavilion m8020n PC Desktop
I have HP 7700 system,with Vista Operating System. It had issue which resulted to me formating it. Now I cant activate it even online. I keep reinstalling the Vista OS every 30 days. Pls how can I freeze...
Vista sucks anyway, and anything that can run Vista should be able to run Windows 7. This is a blessing in disguise. Buy Windows 7 Home Premium Upgrade and install it.You legally qualify for the upgrade version if your computer came with Vista. You can use instructions here to make the upgrade version work on a clean disk:http://windowssecrets.com/top-story/clean-install-windows-7-from-the-upgrade-disc/
Jan 27, 2012 | HP Computers & Internet
I need a dvd driver for HP pavilion dv6704nr running Vista Home Premium 32-bit.
Windows XP and Vista and 7 have built-in device-drivers for all CD-readers and DVD-readers.
Download the free 'VLC Media Viewer' software, to play DVD-movies on your computer.
Feb 21, 2011 | HP Pavilion dv6704nr Notebook
Hello, my hp pavilion desktop (purchased early 2008 running windows vista) turns on, makes the necessary beeps/startup noised, but there is no picture at all. Tried plugging into a different monitor, same...
HELLO, IF IT IS ON BOARD VIDEO,YOU HAVE TO TAKE IT TO HP SUPPORT CENTRE,BUT YOU CAN TRY INSERTING THE RAM PROPERLY INTO IT SLOTS AND SEE WHAT WILL HAPPEN.
Nov 18, 2010 | Computers & Internet
Hello can I use AIM share desktop during system recovery at my sister's notebook hp pavilion dv 6700 ? vista home premium sp1
It would not be possible since AIM share desktop only runs in windows environment. if you would be doing a system recovery, the contents of the HDD will be refreshed meaning it would run starting outside of windows.
Jun 04, 2010 | HP Pavilion DV6700T Notebook
My brother just gave me his hp pavilion dv4-1313dx laptop and i want to reinstall windows vista. how do i remove windows xp? i just want to clean all of his garbage out of my laptop then reinstall vista,...
First check the System requirements The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK
If your computer is compatible follow directions below.
Option 1
loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
OR
Option 2
Note for the option below The computer must be configured to start from the DVD drive.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Please rate this a fixya
May 18, 2009 | HP Pavilion Notebook
I reformated my desktop and theres no sound on this hp pavilion a6000n i need sound
he has
  • Windows Vista Home Premium
  • Windows Media Center
  • or windows xp and here the website to download the drivers for vista, xp, media centre
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3377269&lc=en&cc=us&dlc=en&lang=en&cc=us
    Apr 15, 2009 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
    Lost items in left side of start menue.
    Delete your profile from C:\Users\<your login name> and restart.
    Please do a backup of your important files from "My Documents" and 'Desktop" if you have any important files there.
    Mar 22, 2009 | Microsoft Windows? Vista Home Premium...
    Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
    Hallow Dear,
    Please use this link to download Drivers for your PC (20M)
    XP/Vista - ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38688.exe
    Operating Systems
    Microsoft Windows 2000
    Microsoft Windows XP Home Edition
    Microsoft Windows XP Media Center Edition
    Microsoft Windows XP Professional
    Microsoft Windows XP Tablet PC Edition
    Microsoft Windows Vista Enterprise 32 Edition
    Microsoft Windows Vista Home Basic 32 Edition
    Microsoft Windows Vista Home Premium 32 Edition
    Microsoft Windows Vista Business 32 Edition
    Microsoft Windows Vista Starter 32 Edition
    Microsoft Windows Vista Ultimate 32 Edition
    Microsoft Windows Vista Enterprise 64 Edition
    Microsoft Windows Vista Home Basic 64 Edition
    Microsoft Windows Vista Home Premium 64 Edition
    Microsoft Windows Vista Business 64 Edition
    Microsoft Windows Vista Ultimate 64 Edition
    This Will Completely Solve your Prob; if there is no any internal Hardware Problems with Quick Lunch Buttons
    (I feel there is no any coz u mention about Ding Sound. That mean your system is recognizing your key input & all you need is Just program those keys – above setup will do that)
    ** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
    Thank you & Best Regards
    Dinu….
    Dec 20, 2008 | HP Pavilion dv4000 Notebook
    Installation of Windows XP Pro on Hp Pavilion laptop
    what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
    make sure to save a back up of all of your important files before you do that.
    Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
    HP Pavilion dv6000z Notebook Logo
    4,692 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
