Question about Whirlpool Washing Machines
Not finnishing cycle AWM 8121 washing machine
    Scholar:
  • 111 Answers
Can you manually advance it through all the steps of the cycle? If so, you can live with it until you replace the little timer motor. (I once carved a tiny wooden gear to replace a tiny nylon gear on the timer, and that worked fine for another 20 years.) If not, then I'd say the control unit needs replacing.
Posted on Nov 11, 2008
Whirlpool awm 8121 leak
down by the water solenoid those leak sometimes or a loose hose if you cant fid it it might also be the seal in the drum
Aug 25, 2014 | Washing Machines
What would cause a leak in whirlpool awm 8121 ?
Try putting some cardboard under the entire unit. Run it and pull it out to see the approximate location of the leak, then inspect in that are closely you should be able to find it.
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
Front loader whirlpool washing machine won't go thru cycles.
"o" is an unsual code. usually it will have an "f" then a number. it may be that you are having a draining issue. is the unit full or have some water left in it? if so take off the front panel and see if you can remove the sump cover. be ready for water to come out, then remove whatever is blocking the pump and sump area. it most liekly has lint or items in there causing no drain.
Dec 28, 2008 | Washing Machines
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
224 people viewed this question
Dan Webster
Dan Webster
Sal De
