Question about DeLonghi Heating & Cooling
My pinguino super switches on, runs, compressor starts, supplies cold air for plus minus ten to fifteen minutes the cuts out.
    Scholar:
  • 131 Answers
IF YOUR COMPRESSOR IS WORKING FINE & THE UNIT IS GETTING COLD I WOULD HAVE TO SAY YOU HAVE A THERMOSTAT PROBLEM.
Posted on Nov 11, 2008
Engine running rich
Most likely throttle positioning sencer
May 08, 2016 | Cars & Trucks
Pinguino PAC 60, I bought this recently from an auction. When powered on , switched to * and temperature control fully anticlockiwse, the temperature LED flickers at a fast pace. After a few minutes the...
filled what tank? if the compressor never comes on it could be because of no or low freon levels or bad start components to the compressor or a bad capacitor to the compressor or fan motor. you may need to call a company to take a look at it, i am a technician myself so please just get a couple different opinions so you do not get ripped off.
Oct 22, 2013 | DeLonghi Pinguino PAC-02 Air Conditioner
2001ford f 250 super duty diesel air conditioner problems
Sounds like a fan clutch problem or ??
Can you drive it and when it quits cooling check and see if the compressor is still running ?
Jun 29, 2012 | 2001 Ford F250 Super Duty Super Cab
My LG unit starts fine and cools but the fan runs at hi speed only and I cannot select any other speed although I hear a beep when they are seleted
In Auto mode, and jet cool or fast cool (if option is there in your remote), you can't change speed. Keep cool mode and then press fan again and again still you get required speed. Suppose, as you said beep sound is there when you select speed, check related speed terminal in PCB. If power is there, winding open in motor. If no power, replace/repair PCB. Thanks and hope it's helpful.
Jan 26, 2011 | LG LS-K1830CL Cool Mini Split Air...
New a/c system replaced and not blowing cold air
Make sure you check the super heat on the unit. (super heat is the temp of the suction line at the condensor outlet minus the suction pressure. It should be fifteen degrees less than the suction pressure.) This should be done by a skilled refridgeration tech. Whom ever installed the equipment should be able to help you with this.
Jul 31, 2009 | Heating & Cooling
DeWalt emglo compressor does not start
hello,
well,you have to release the pressure,the cut out pressure at 120 psig.reached,and the cut in pressure maybe at 40 psig.so after realeasing pressure at cut in the compressor will run.if the compressor not run at cut in or after releasing check your power supply if still have,swicth off power breaker,by pass pressure switch,by disconnecting the line on terminals of pressure swtich,connect the line w/out pressure switch
the wire line should supply the the compressor,
open the service valve of compressor,switch on
observe if compressor run and develop pressure or air is coming out to nozzle,if that so switch off again and replace pressur switch.you have defective pressure switch,regards rate me,thanks
May 02, 2009 | Heating & Cooling
Nocking motor
the motor starts nocking after about ten to fifteen minutes of running.and looks like it is overheating but i do not understand the overheating signals on the dashboard.
Jul 23, 2008 | 2001 Dodge Intrepid
Air not getting cold
You should have the unit serviced. If the compressor runs and does not cool it may have lost its refrigerant charge.
May 21, 2008 | DeLonghi Pinguino PAC-210 Air Conditioner
Brewer in dire need
this is gold, is strange to heard that one fails, but have to happen, dont leave regular people tuch it, get a good tech, it seems to have a sort problem, I know the compressor are ok becouse it have dobble protection, must be a capacitor problem..good luck
Aug 08, 2006 | DeLonghi Pinguino PAC-GSRU Air Conditioner
Heating & Cooling Logo
155 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
