Question about Hitachi 51SWX20B 51" Rear Projection Television
Tv turns itself on and off
For a while now i'll go into tv room and find set turned on. at times it will turn itself off while I'm watching. nobody can seem to find anything wrong,at least till warranty is over!! It bothers me because it is very intermitant and until they are watching it happen before them, nobody believes its happening. I'm upset that while I'm on holidays or gone for a few days it will be on! I have seen it turn it turn itself on and when I've gone back later, its off! I have not seen it turn on actually,but find red light on and faint glow to picturte as it has no input because other components are off. It had been shut-off correctly when I left the room. ghosts have been suggested, but I have a hard time with that one!
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
Dynex dx-lcd32-09 tv won't stay off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 11, 2016 | Dynex Televison & Video
Why do my tv turns off by it self
you sir have a paranormal problem and might have recently watched the ring movie. have a paranormal specialist team come in and set up cameras in that room.
Aug 29, 2012 | RCA Televison & Video
Over tv its getting aoutmatically off
Hello
Put your hand on the back of your TV to check for overheating, if your set keeps switching itself off without warning.
Many TV sets come equipped with a safety feature that switches the power off if the set gets too warm.
Check the cooling vents located at the rear of your unit. Vents can collect dust and dirt, resulting in the fans becoming blocked and failing to work properly.
Remove dirt from the vents with a damp, clean cloth. Ensure the air conditioning is kept at adequate levels in the room where your TV is located. Keep the drapes shut on hot, sunny days to keep the room cooler.
Check the sleep-timer function on your TV if it keeps turning off. A sleep-timer is used to turn a television set off after a certain period of time has elapsed. If the sleep-timer is not turned off, your television will continue to turn itself off after a certain period of time.
If the problem persists,then a heat sink has gone bad.
The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
Take a can of compressed air, open the back and clean the dust off the circuit boards.
NOTE;opening the TV VOIDS warranty!!
Dec 22, 2010 | Televison & Video
TV TURNS ITSELF BACK ON AFTER BEING TURNED OFF
The most common thing is malfunction in your remote control. Try moving the remote control to another closed room, and see if it still does it. If it does... well, I know how to setup a TV to turn itself off after a period of time you set, but how to turn it on? no.
Also something, might be stupid, but I'd tell it anyways, is that someone is fooling you by ór using the remote control, ór having another remote control, and turning it on all the time.
And another thing. By "off", do you mean standby? or actually turned off by pressing the button? Because this is only if it is turned off with the remote control. If it is explicitly turned off by the button, then it might be a malfunction on your tv, meaning you could call the support of the company that makes these tv's, and if it is actually a malfunction, you could get a new tv for free, if your warranty hasn't outdated yet.
That's all I can think of, I hope it helps.
May 04, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
TV turns on & off
Hi there!
Exterior equipment attached to a standard tv cannot cause the set to switch on/off by itself.
I think you may have a power supply fault or else loose solder connections on the board, hence the "warming up" intro before the fault shows itself.
My suggestion would be a service technician if you are not familiar with electronics or TV's. Regards, JUS004
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
Samsung dlp hdtv turns itself off
Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
Tv keeps turning off
take your remote control and find the symbols shows watch click,then will show you the time setting if you want my be your tv to turn off 10 mn or 5mn or 60mn.then turn off the time there.
Aug 21, 2007 | Durabrand DU1901 TV
Hitachi 51SWX20B 51" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
