Charged ad checked battery maint6ains charge but will not start engine. engine drags
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
SOURCE: The lawn mower starts and then sputters and shuts off
Sounds like you have a carb problem here. If your not familiar with the carb have someone qualified to do it. Other wise it sounds like the jet in the carb has dirt in it, obstructing the gas passage. Most of those jets are directly in the bottom of the carburetor. Remove it and be careful not to drop the bowl because if you do you could cause the float to move and that could get stuck and then not shut the fuel flow off to the bowl when re installed. Good luck
