Question about Bosch Dishwashers
There is all water still left in the bottom and there are no lights on the front panel. have pushed the button but nothing happens
    Problem Solver:
  • 12 Answers
Open the the door look at bottom where the water is accumulating you may need to remove the dishes and the bottom trey, In the very most lower corner of the inside of the dishwasher you will find a drain it will not look like the drain in you sink but more like a 2 1/2 inch cylinder with a mesh like screen, this is the drain screen and it will get clogged from time to time, Depending on the make and model of your dishwasher will determine how this drain cover is removed, The most common removal is to use a Philips head screw drive and remove retainer screw, Now you will need to put your hands in the muck and feel down inside the hole where the gross stuff has plugged up the drain and remove most of it the best you can, After you finish removing the muck you will need to use that Philip head srew driver and remove the screws that secure the kick plate, this is the most lower portion of the dish washer in the front, Now you will be able to access the pump drive it is the plastic or aluminum with 2 to 3 hoses connected to its body. At the base of the pump you should be able to turn the pump manualy, this will help the motor start turning the pump by itself. be sure to put the drain screen back on and secure it with the retaining screw. Reinstall the kick-plate, To prevent this from happening again get the kids to remove the muck from the drain and they will never put a plate full of food in the dishwasher again. Good luck and happy fishing.
Posted on Nov 11, 2008
Dryer stopped with 30 minutes left on the timer, I reset the timer and pushed the start button nothing happened I opened the door the light came on shut the door tried to start again and again nothing. it...
its not the timer its your thermal fuse located in the back of the dryer behind the panel if not there it will be in the front at the bottom behind that panel. Its usually placed on the vent outlet housing.
Dec 17, 2010 | Dryers
Dishwasher leaking
just an idea...if i'm understanding you correctly,could the door seal be creased there or folded over by use and age to permit this to happen? cause you said nothing is missing
Aug 28, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
Mar 22, 2008 | Watches
Frigidaire affinity king-size capacity washer
my washer is not spinning the water out.what could be the problem?
Sep 23, 2007 | Frigidaire ATF6000ES Front Load Washer
Dishwashers Logo
157 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
