NEC MultiSync  17 in  17 in. Flat Panel LCD Monitor
Problem for NEC MultiSync (LCD1715) 17 in (Black) 17 in. Flat Panel...
Monitor needs help turning on
By prettyhorses on Nov 18, 2006
When I have the monitor off for any period of time it doesn't want to come back on. When I push the button on the monitor next to the power button it mostly comes on. But it fades in slowly. It is getting more and more difficult to light the monitor up. Sounds like a monitor problem to me,,,what do you think??
Solution #1
posted on Nov 26, 2006
Not Rated)
El Duderino
Rank: Wiz
Rating: 90%, 386 votes
Hi prettyhorses,
Sounds like the back light inverter board is bad.
It's a very common problem.
LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it)
The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display.
If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad.
The inverter board and CCFL's are replaceable.
Good Luck,
El Duderino
Was this helpful?
Yes
No
Popular Solutions for NEC MultiSync 17 in 17 in.
Questions and Unsolved Problems for NEC MultiSync 17 in 17 in.
Do you recommend NEC MultiSync (LCD1715) 17 in (Black) 17 in. Flat Panel LCD Monitor?
Answer
Answer
I've got a wall bracket for my monitor, but can't work out how to remove the built in stand. The... (More)
Answer
I'm trying to reset the power saving setting on an Acer V179 and I can't figure out how to do so--it... (More)
Answer
Hello, I have a Synaps 24'' LCD Monitor AKA: YURAKU or IOLAIR Model: MB24WKH TN Screen:... (More)
Answer
We've been using this monitor for over 1 year with no issues. Today the video disappeared. We get... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in , IL
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
