Question about Olympus Stylus 700 / 700 Digital Camera
OLYMPUS DIGITAL ALL WEATHER
When I turn on , on the screen I get the MESSAGE " ZOOM ERROR" and suddenly the power goes off.
  • 62 Answers
If the error is unsolve with martin sain check the FW of your lense or the gear of the motor of your camera!!..i think the lense had disconnected or there something wrong in the gear!!
Frank!!
Posted on Nov 12, 2008
    Novelist:
  • 150 Answers
1) Make sure that the batteries are in good condition
2) Check and clean any dirt or corrosion from the battery terminals.
If the power supply voltage suddenly drops during initialization,
or when the lens is trying to extend itself, it could produce this
kind of error.
3) Make sure that the lens extension tubes are not mechanically
jammed.
4) Remove the batteries, turn the unit ON and wait for it to fully
discharge any internal capacitors, then put the batteries back
and try to turn the unit back on. This should fully RESET the
internal CPU.
Generally this kind of error means that the camera's internal
computer is trying to activate the lens zooming motors, but
the motors fail to move as expected.
Other causes could be:
a) burned out ZOOM motors
b) burned out motor drive circuitry
c) bad motor positioning sensor
d) defective computer components
e) failed internal firm-ware.
none of these cause are user fixable.
Hope this helps
Martin
Lens Error
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Cameras
Zoom not working - Screen goes blue and codes 1e13 3403
Was not fixed. Do not have this specific camera.. Is a different Olympus.
Jun 16, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Error message for olympus camedia digital camera D-560 Zoom
When I transferred those particular pictures to my laptop for some reason they were partially deleted from the camera which gave the 'picture error' message. Deleting that picture completely got rid of the message.
Nov 19, 2008 | Olympus Camedia D-380 Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Olympus stylus 600
look for a small pinhole on the camera body. insert a pin with power on to reset the camera
May 25, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Olympus Stylus 700 / 700 Digital Camera Logo
109 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
