Back to:
Tags:
Epson Stylus Photo R220 InkJet Printer
Both Ink & Paper lights flashing! (by 2 users)
posted by JayBirde on Oct 28, 2006
Clear out of the blue, when I went to turn on my Epson R220, the power light comes on for a few seconds, the printhead moves around a bit and then the power light goes out and the ink and paper lights flash together. I have bought new cartridges and they are doing the same thing. I have run the Epson Interactive Troubleshooter and followed all the steps. I have checked for paper jams (little pieces too) and I cannot seem to overcome this problem. Any help would sure be appreciated! Thanks.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 22, 2008
i turn my printer on to print will not it says off line error what do i need to do
Best Solution
posted on May 23, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
if both lights flashing open your window and fire the fucker out the window make sure packi is near by as you can kill your printer and packi at same time
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Both Ink & Paper lights flashing!:
I don't want to Accept this solution
Solution #2
posted on Mar 11, 2007
Thanks for Trying (70)
Inky
Rank:Guru Guru
Rating: 85%, 699 votes
Hi JayBirde
Do the lights flash Together (not alternate) and is it a quick flash (0.1 second on 0.1 second off)? If so, check the Status Monitor for a message. If it says Fatal Error or General Error, then you have a task on your hands!
If the lights flash alternate (0.5 second on 0.5 second off) then this indicates a maintenence error and the status monitor should say parts inside your printer have reached the end of their life - or something similar. This much easier to fix with an R220 Rescue Kit from www.TheServiceManualShop.com - use their search to look for R220 Rescue. If you can't find it, just drop them a line and they will create one for you. Delivery is via instant download so no waiting around to get your machine fixed.
If you have a general or Fatal error it means the printers head can not move using the norm,al amount of force - i.e. something is in the way. You can check a few things:
Ensure their is nothing in the path of the print head - paper, foam from the pad, head lock not retracting, toy soldier on manouvers in the mechanism etc
Chech the encoder strip ( a grey-ish looking plastic strip, near the drive belt for the print head) is clean and attached.
Check the lid for the ink cart cover is full closed.
Thank You!
Solution #3
posted on Jun 12, 2008
Not Rated (0)
Eagle_tech
Rank:Wiz Wiz
Rating: 83%, 277 votes
Sounds like your ink pads are full, usually last only 1 yr - 1 1/2 yrs. do not throw out it is planned obsolecents by Epson.
go here for a little item that will save money and fix that
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=+++Waste+Ink+Tank+for+Epson+
Thank You!
Can you Help with these Printers problems?
blank paper print
after I try to clean the waste ink pad where is the print...
This laptop has Webroot Parental Controls installed with...
Dear Techs: I am trying to retrieve an object that fell...
I'm trying to find a template so that I can print to cd...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
