Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
No suction I have new belts. Everything is clean. No clogs. When I turn it on it smells like rubber , the brush doesnt spin. Everything seems to be free flowing.. Roller brush isnt stuck on the ends. Took off hose to make sure no clogs anywhere. There is not even suction thru the hose with the handle in upright position.
  • Anonymous Mar 13, 2014
    no suction at base but ext hose has great suction ..took out brush roller and can't find clog in bottom pipe, brush does spin when on
  • 833 Answers
Generally, the problem is that the belt is not running the brushes.  This is caused by one of the following:
  • beater brush is jammed.  This is either an object stuck in the brush or immediately behind it in the housing or the bearings are gummed up with floor dirt
  • the belt is broken and rubbing against the motor shaft
  • the plate holding the beater brush has a part broken off which is causing the beater to jam
Clogs are not the problem here.  Inspect and resolve the above.  Use a new belt.  Never reuse this one.
Posted on Nov 11, 2008
  • 397 Answers
Ok...with the vacuum on and the hose in your hand checking for suction, try pushing the cover that is over the bag against the unit,,,sometimes there is a leak and it doesnt give any suction...
  • 148 Answers
You still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
I took the vacuum apart and cleaned it. Now there is an odor coming from the round filter and the vacuum is not picking anything up.
  • hi there
  • Does the odor smell like burnt rubber....if so you may have burned out the belt which is common. The filter can smell if you have pets and the machine will blow the odor back in to the room after the filter gets older.Check to see that the roller brush is spinning when it is turned on if not shut it off and try to turn it manually with your hands. If it turns very easily the belt gone if it is almost impossible to turn you need a new roller brush.You can replace the filter to help with the smell but if it is the belt you smell it will go away in time. Also make sure that you have the container on perfectly as if it is not it will not create a perfect seal and you will have very little suction. The other thing you can check is the hose to see if the suction is good through it. If the hose has good suction then the power head may be plugged with something and you will need to get a screwdriver and take the bottom plate off the same way as if you were changing the belt and then you can look for a blockage as well as access the belt and roller brush. I hope this was helpful to you ...good luck
Oct 13, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
I vacuum seems not to have any suction; for a while the attachment had suction; now it does not.
If you have checked for the obvious clogs and obstructions, be sure the belt is working properly and if necessary, attach a new belt to the unit. At the same time, clean the beater brush and lubricate the ends between the brush and the hard rubber holders.
I would also check the hose for any potential leakage.
Paul
Sep 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The motor is running, the roller brush spinning rubber smell
Sounds like the main suction pipe is blocked.
Unplug, and in good light - see if you can see any obstructions in the pipe from the prush area to the bag (in a bagless vacuum) or to the fan in a bag model.
Aug 04, 2009 | Vacuums
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Brushes don't spin but it still has suction
The brushes are usually connected to a motor by a rubber belt. These can wear out and snap (particularly if the brushes are clogged with hair). Usually the bottom of the vacuum can be removed by undooing a few screws and gently pulling it downwards. If the bottom doesn't want to come off, hunt around for any screws you may have missed - the designers seem to think it's funny to hide them. Once the bottom is off, check the belt and remove any hair wrapped around the ends of the brush bar. If the belt is broken you will need to find a replacement.
Apr 23, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
167 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
