Check your ram sticks one or both could be bad that could be the reason for system beeps and not booting ( open system remove one stick and restart system. If system still beeps shut down replace ram stick and remove other stick and reboot) . I hope this solution goes well for you.
If your box is an intel board as I will assume from your lack of information, then use this guide to plug all your wires. Switch to page 46 for pin references.
Sounds to me like you have a bad CMOS battery. That battery provides enough juice to keep the hardware clock and settings active. The battery should be a size 2032 and you can find a energizer brand at any store almost. Shouldn't cost more than a couple of dollars. Let me know if that does the trick.
Hook the two together on the one working IDE connector. Put your hard drive as the first device on the ribbon cable and make it the master using the jumper at the back. Hook the DVD to the second and set it's jumper to slave. Install your OS then try to figure what's up.
try setting up your CMOS by setting it to optimized default settings, then save and exit. turn off your computer, plug off the power cord from your Battery Backup or from your AC supply. if still didn't worked out. try replacing your power supply
The E114139 94Version 0 is an ABIT KD7 non-raid board This link will allow you to download the manual, I would suggest the http site for download as some times the recommended site has errors.
