Question about Hotpoint WMA35 Front Load Washer
Washer emitting burning smell and smoke on fast spin
The machine had reached its spin cycle and was making odd noises but was still working. When it got to the fast spin it was far too loud to be normal. When I looked at it smoke was whisping out of the dispenser drawer. I turned the machine off. When I opened the door, a lot of smoke was coming out and there was a strong burning smell. I took the clothes out and the smoke continued to billow out. This eventually stopped. I took the top off the machine and put it on the fast spin cycle to see if I could see where the smoke was coming from. It seems to be coming from inside the drum itself (rather than from the motor or belt). We took the front and back off the machine and shone light into the drum. It doesn't seem as though anything is stuck inside the drum. I thought maybe there's a problem with the heating element but can't figure out why smoke and smell only appeared on the fast spin cycle when surely the heating element isn't working at this point. Please help. I have loads of washing to do!!!
  • 1 more comment
  • Ron Noreen
    Ron Noreen Jan 09, 2014
    Mine is doing the same thing it cannot read the spin speed and begins smoking cleaning the trap did not work time to call service
  • Anonymous Mar 20, 2014
    DURING THE FAST SPIN THERE WAS A STRONG SMELL OF BURNING RUBBER THEN AFTER THE SPIN HAD STOPPED AND THE DOOR HAD EVENTUALLY UNLOCKED;SMOKE CAME OUT OF THE DRUM AREA
  • Anonymous Mar 24, 2014
    smells of burning and smoke coming out
    Problem Solver:
  • 9 Answers
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
Posted on Sep 14, 2007
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
I have a Kenmore Oasis Elite 110.280442700. I bought it at the beggining of 2008, never has given me any problem. About a month ago, it started to make a really loud noise during a spinning cycle, as if it...
April, You say you are suspicious that the smoke could have originated from the motor, BUT have you confirmed it? Have you tried running a short cycle without a load to see if the spin cycle rattles the machine or whether the machine works? Watch for smoke and turn off the machine immediately if you see or smell burning. If the motor is burnt, I think replacing should not be an option but rather replacing the machine should be considered.
Mar 01, 2014 | Kenmore 22642 Top Load Washer
Smoke coming from inside drum after spin cycle
The noise would possibly indicate that your drum bearings are on their way out, this would more than likely mean a new spider assembly, tripod in shape and houses the bearings through the drum, as well. They come in kits or bearing assembly alone for various prices, usually around 40 pounds for the kit but it would be a very difficult job if you are not familiar with this type of work, bearing extractor kits are best used but more cost, drum seals may also be needed.
Jan 23, 2014 | Hotpoint WMA35 Front Load Washer
Washer started to smoke during spin cycle then a cracking noise began after that.
You may just have a defective drive belt. The motor itself will smoke under certain failing circumstances. Can you give me a model # ?
Jan 07, 2013 | Washing Machines
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
Hi my candy washer/dryer keeps making a odd noise when quick spinning. Lastnite there was a 'odd smell like burning rubber. when i opened it there was a little smoke, and a bit of rubber inside. is it...
You have a mis-aligned drum and you should check the perimeter rubber gasket to verify if there is some rubbing on it. I can't say for sure what the odd noise is except for a rubbing situation. If you ar able to replace the rubber then replace it and I hope you have been removing and cleaning you gasket to prevent any mildew build up. I would replace the washing machine if the motor and transmission is not operating. Good Luck
Jan 09, 2011 | Candy CNW156 Front Load Washer / Dryer
Frigidaire Frontloader 417.39022890
Hi thanks for the question. I would look at the pump. remove bottom panel. pump on the right, remove hoses, clean out the pump. thanks the appliance doc
Oct 07, 2008 | Estate TAWS800JQ Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint WMA35 Front Load Washer Logo
1,360 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
