Question about Panasonic Televison & Video
PANASONIC VIERA TH42PV30 TURNITSELF OFF AND FLASHS RED CANNOT TURN THE UNIT BACK ON AGAIN ??? PRESS THE ON BUTTON AND THE RED LIGHT FLASHES AND THEN THE UNIT TURNS ITSELF OFF
  • agray294 Nov 10, 2008
    My Viera TH42PV30 PLASMA TV WILL NOT TURN ON AT THE SET. THE STANDBY LIGHT COMES ON AND THE TELEVISION SOUNDS LIKE IT WILL START AND THEN SWITCHES ITSELF OFF.THE LIGHT STOPS FLASHING AT 13 FLASHES REMAINS SOLID FOR A PERIOD AND FLASHES AGAIN STOPPING ON 13 AND THEN CONTINUES THE SAME PROCESS AGAIN AND AGAIN. THE FLASHING RED LIGHT IS A CODE INDICATING THE PROBLEM I THINK ??? CAN YOU PLEASE HELP SOLVE THE PROBLEM
  • agray294 Nov 11, 2008
    i GUESS I WAS HOPING FOR MORE THAN TO RECEIVE THE INEVITABLE MESSAGE TO TAKE THE UNIT TO THE REPAIR MAN
  • Panasonic Master
  • 19,396 Answers
The TV is in protect mode.
Try unplugging power cord for ten minutes or so, and see if this help.
If the TV does not restart, then try unplugging for longer.
If still no luck then that means that there is an internal fault, let me know if you get the led blinking a number of times, or if there is an error code message on the TV display.
Posted on Nov 11, 2008
  • 320 Answers
A 13 blink error is usually a communication error, meaning the data between the internal computers is not being transferred or read properly. The most common cause of this is a bad A board.
  • Any Guy
    Any Guy Nov 11, 2008
    If you plan on trying to get an A board and replace itself be aware. there are DANGEROUS VOLTAGES inside thr tv which can cause injury or death. Use extreme care when opening the TV, unplug it before service and let it sit for at least 30 minutes before attempting service
  • Any Guy
    Emissionwhiz, you are wrong, this error has nothing to do with the power supply, it is a communication error, please restrict your comments to your area of expertise.
    Top Expert:
  • Panasonic Master
  • 79,186 Answers
YOU WILL FIND THAT THE HIGH VOLTAGE CIRCUIT BOARD HAS FAILED, THIS IS WHY IT SHUTS OFF, THE BOARD IS SHORTED, THE COST TO REPAIR THIS WILL ALMOST EXCEED THE COST OF A NEW LCD TV, IF YOU FIX IT THEN IT WILL MOST LIKELY WORK FOR ANOTHER YEAR OR SO AND FAIL AGAIN, DO YOURSELF A FAVOR AND REPLACE IT, THE NEW SETS ARE CHEAP AND GREAT QUALITY.
    Brigadier General:
  • 6,966 Answers
Offhand, the flashing indicates that the unit has switched to protection mode. On some models, the number and sequence of flashes indicates the general area of the fault and where initial diagnosis can begin. Eventually the unit has to be opened up for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Incidentally, in the hope that this is a simple glitch, perhaps you can try unplugging from the mains and removing all connectors. After an extended period, reconnect and verify connections and try again.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
  • Louie  Role
    Louie Role Nov 11, 2008
    Hi again,
    I understand. When I posted, the info re 13 blinks was not yet available and therefore the proposed solution was based on your initial posting.
    Nonetheless, please be informed that there are others who posted solutions to your concern after you posted back with the 13 blinks information. If you are unable to view them and with their kind indulgence, I will post below their comments:
    mistersony
    "A 13 blink error is usually a communication error, meaning the data between the internal computers is not being transferred or read properly. The most common cause of this is a bad A board.
    If you plan on trying to get an A board and replace itself be aware. there are DANGEROUS VOLTAGES inside thr tv which can cause injury or death. Use extreme care when opening the TV, unplug it before service and let it sit for at least 30 minutes before attempting service"
    emissionwiz
    "you will find that the high voltage circuit board has failed, this is why it shuts off, the board is shorted, the cost to repair this will almost exceed the cost of a new lcd tv, if you fix it then it will most likely work for another year or so and fail again, do yourself a favor and replace it, the new sets are cheap and great quality."
    Cheer.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to open it and then locate the power
and then clean it
may there is something stuck on the power!!
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic Viera 42" TV won't tun on
This problem happens when you connect a DVI-HDMI input to the back of the set. It can happen other ways too though. Press and hold your power button, which will reset the unit to it's factory defaults, and should return it to normal use.
Mar 03, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Pairing Sky+ Remote with Panasonic Viera remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Dec 29, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My panasonic viera tv has blown its 5amp fuse. i have replaced fuse but now it will not start up the front red light flashes but the fan does not start up and there is no picture can u help
My problem is exactly the same. The TV blew its fuse and will not start again. The front red light flashes when we press the remote but otherwise there is no response.
Aug 18, 2008 | Panasonic Televison & Video
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
