Question about Dell 962 Photo All-In-One InkJet Printer
Won't print at all and printer cartridge keeps flashing
I have tried everything. I need to do something internally in the printer.
L.
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to unset the cardtridge
Posted on Nov 10, 2008
Both paper jam and ink replacement lights are flashing.
Sounds like print cartridge collided with paper. Open both covers. Try to remove paper carefully without damaging print cartridge. you may need to remove print cartridges to get paper out. Then close every thing without print cartridge in. Reopen covers reinstall print cartridge/s, hopefully, everything returns to normal. It will probably say something about going through the process of realignment.
Mar 13, 2015 | Office Equipment & Supplies
Printer keeps giving alignment problem message
hello, remove cartridges, clean with something soft the wiring of both printer cartridge slot and cartridge itself, make sure you use alcohool, sanitary or even parfume wich dries fast and is not greasy, after that power up printer and check to see if everything is alright, if other error ocurs reply here.
hope that helped, best regards
Feb 28, 2014 | Lexmark International Lexmark 7300 Series
It won't print and the light keeps flashing. I lost the instructions!
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Feb 13, 2012 | Lexmark X1240 All-In-One InkJet Printer
Toner light keeps flashing and printer won't print - even though it has a brand new cartridge.
Please try the following steps.
  1. Turn the printer OFF.
  2. Reseat the cartridge.
  3. Switch the printer ON.
Or
  1. Open the top cover.
  3. Close the top cover.
Jul 02, 2011 | Lexmark E232 Laser Printer
The on button keeps flashing and when i try to print something it shows it's printing on screen and actually is not printing a thing. if it's something i can only print 1 time i have lost that...
I had the same issue, turned out that one of the cartridges had malfunctioned. Take out both cartridges, close the cover, and see if the light goes steady. If so, reinsert just one cartridge and try again. In my case, it was the color cartridge; when it was removed, the blinking light went steady and I was able to print in black just fine.
Aug 20, 2010 | HP D1660 InkJet Printer
Printer wont print
Turn the printer on. Remove the cartridges. Gently clean the electric contacts on the cartridges and the cartridge carrier. Put the cartridges back in. If the light is still flashing, and your printer won't print, one of your cartridges is faulty. I suggest you go to the refill shop and consult them which cartridges needs a replacement.
Does any message appears on your monitor when you try to print something? Usually, a message saying "problem with black/color cartridge" or something similar, that's why I am asking.
Dec 22, 2009 | HP DeskJet 930c InkJet Printer
Printer has all lights flashing
Remove all ink cartridges. Then unplug your printer and plug it in again
Jun 07, 2017 | HP DeskJet 5150 InkJet Printer
Lexmark z52 problem
got similar problem
mine flashes 12 times and doesnt print at all
when i remove the black cartridge, everything seems to be working fine
think my problem got smth to do with the black cartridge but i never had a problem like this before
plz help
grtz
Apr 10, 2008 | Lexmark Color JetPrinter Z52 InkJet
Ink light wont shut off
You will have to change the cartridges in the store that you have bought them, cause at least one of them is with problem in the internal circuit.
Mar 25, 2008 | HP DeskJet 5550 InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
