Question about Linksys WRT150N Wireless N Router - 300Mbps, 802.11n , 4-Port
Internet cut out
My internet keeps on cutting out when ever my home phone rings and my internet is very slow same as my download speed
  • 1 more comment
  • tezza1iscool Nov 11, 2008
    My Internet service is ADSL can you help me
  • Anonymous Dec 10, 2008
    my internet cuts out whenever the phone rings and it has gone very slow
  • Johnny Massengill
    Johnny Massengill May 11, 2010
    What kind of Internet service are you using? cable or ADSL? This sound like a problem that your ISP (Internet service provider) should be contacted about.
    Brigadier General:
  • 6,966 Answers
Below is part of my reply to a latter post of yours.
  • internet keeps on making this weird sound on my home phone - do you have a ADSL In-Line Filter/Splitter like the image shown below? If yes, pls check if the phone is connected to the phone and vice-versa. There are instances where they could have been reversed. If correct, it may require replacement.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 24, 2008
My phone operates very slow, how can I speed it up?
there are several reason why phones work slow
the memory is too full to allow fast operation
too many icons or apps on it
mostly , operators do not keep track of downloads/uploads and the amount of supplied bits is over run so the service provider cuts the transmission rate back
May 21, 2015 | Cell Phones
How to extend ring time before answer machine cuts inExtend ring time
you're gonna need to go to your menu options to change the number of rings. Google your model and then look under manual. Perhaps this is it: http://www.home-phones.co.uk/assets/uploaded/documents/384_BT_Synergy_5500_userguide.pdf
Nov 04, 2014 | British Telecom Synergy 5500 Trio 4Line...
How I can to stop movies for cutting off to reload
not sure how that relates to a remote control---but it sounds like your download speed is slow,you dont say if you are using wifi or a home hub,if its wifi then you need an amplifier also make sure your graphic driver is up to date and any other programs related to video like flash player,finally only run minimal programs at a time not 10 in the background it makes your computer slow,look in the taskbar to see how many are running and shut them down,try msconfig
Jul 21, 2014 | Roku New Original 3100X Remote Control
When the cricut is cutting it tears my paper even though the cardstock is good and the machine cannot cut anything intricate. I tried changing the blade, but the same problem still exists
After having the Cricut for many years, I finally figured out how to cut the intricate cuts. Use multi cut 2, speed on med (3) and pressure on 4. I also keep my blade at 4. It takes a lot longer to cut but it cuts out good!
Mar 12, 2010 | Provo Craft Cricut Disney Font Cartridge
Slow to connect to any webpage and at times drops
has nothing to do with the laptop its your internet connection, you may have exceeded the monthly download limit in which case your internet company will halve your speed and if you continue to download stuff they will cut you off, thats probably the most likely thing assuming this info is relevant to you
Nov 25, 2009 | Compaq Presario Notebook
When cutting softwood/ hardwood should the saw
The blade should only be on a slow speed, for intricate work.
(To make sure that whatever you're cutting, doesn't get too excited.)
Otherwise, it should generally be on the fastest setting.
Thats it, oh except, be carefull and mindfull of what this baby can do;)
Don't forget to rate, thanks
Aug 01, 2009 | Saws
The sound system from South Africa to NZ is very bad. It is not only on my setting. Why?. The old Skype system used to work very well. I can hear the other person well but my side keeps on cutting off!
Probably there is a problem with your internet connections speed.If the internet speed is not good enough then messaging programs such Skype or WLM can cut while talking.First you need to find out which side is the slow sender or receiver then apply for faster service.
Jul 13, 2009 | Computers & Internet
Slow downloading
the porblem seems to be at your ISP.
you need to check with your ISP and verify wha is your upload and downlaod speed. most of the time you should have 5Mb upload and 10Mb download as min.
the speed you are seeing is more like a dialup 133Kb.
Feb 08, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
Internet cut out
I had this problem as well, noise and cutting out. I found out that its only because you are missing one of those special boxes you plug into your phone line then it plugs into the wall.
Without this you will get heavy static and you will lose Internet each time someone calls because thise small little boxes split the signal. Mine came from Qwest using an Actiontec router and the boxes I am talking about have a little phone on them and they are tan.
You should try unplugging all your phone for 2 hours if you still have a problem and see if it is better, if it is, then it has to be what I am talking about. If your still have problems with it cutting out after unplugging all of your phones look for other things that are wireless (iPods, cells, Wiis, Xbox, PS2-3s etc.)
Nov 11, 2008 | Linksys Wireless-N WRT150N Router
Slow internet
If you have 3mb, you have cable internet right? If so, the cable company cuts your speed off if you download too much over a certain period of time. My cable company confirmed this. I can download all I want from midnight til noon, but after that... They will cut your speed off if you download more than a certain amount. You can call them to find out what the amount is.
Feb 04, 2008 | Edimax BR-6104K Router (br6104k)
Linksys WRT150N Wireless N Router - 300Mbps, 802.11n , 4-Port   Logo
144 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
