Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Display panel reads SUDS
The cycle wont finish and the display panel is reading SUDS.
My duet is in pf display and want work
Posted on Apr 12, 2009
  • stanleyrasmu Apr 12, 2009
    pf mode and can't get it to do anything else duet whirlpool
  • 641 Answers
The SUDS message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck!
Posted on Aug 11, 2007
What does 5ud mean 10 minutes from finishing 5 Ud displayed can't open door?
The SUD (not 5UD) code is displayed when excess foam is detected (possibly because excessive detergent is being used). If your machine does not cure itself, you may have to run an "Eco drum clean" cycle (if your machine has it) or a 90 degree cotton cycle with no detergent and no load.
Aug 29, 2016 | Samsung Washing Machines
Won't finish the wash cycle
Initially we 1)used less detergent and make sure its marked 'he' . extra soap suds initiates error codes. 2) ran white vinegar with no detergent to clear suds 3) opened, checked and cleared trap.
Everything worked for a time but codes would return or like you would not finish wash cycle until water line in back of machine was made rigid so there was no chance of water or sud backup. So far so good. Good luck.
May 27, 2014 | Bosch Nexxt 300 Series WFMC2201UC
My washer (a Maytag Epic Z has been making noise and not finishing cycles. I'll start it and go to unload it and it'll read 5d on the display. What is going on?
Try checking this link:
http://www.fixya.com/support/t6154548-error_code_sd_mean_maytag_epic
which I found with a google search. Note that this is an over-suds error, and should go away after a while one the bubbles settle down.
Jan 04, 2013 | Washing Machines
Washer wont finish cycle and display reads "LR"
Hello todd.... This is a common problem with the neptune. It means that the machine needs a new motor and a new motor control board kit. If you are under warranty do a repair. If not, get an estimate before you go ahead and repair it. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Warning I have too many suds
Hi just read your posting.Now just a couple of questions.1st where is the machine draining the water to?Is it into the laundry sink or to another place?Have you removed the clothes from the machine?Have you tried putting a bucket or two of water manually into the bowl and put it to a spin cycle to drain the water out? Please reply with additional information and I can help you further.
Jul 06, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Display read suds, cloths wet and waher will not spin.
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The cycle will not finish. It gives an reading of
LE is a water level issue. Make water is supplied correctly and turned on. Check the waters valves and the water level sensor.
Suds is just letting you know that the machine sensed to much suds. Reduce the detergent you are using and make sure it's HE detergent.
Dec 22, 2009 | Samsung WF337AAL Front Load Washer
Washing Machines Logo
235 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
