My speakers stooped workings and the light turned off
    Sergeant:
  • 306 Answers
First check for fuses. Not knowing the brand, model nor any other clues makes your post really too general to give a more specific solution. Good luck, Steve Medley
Posted on Nov 10, 2008
My GTA San Andreas shut down autimatically while um playing that giving a message "Gta San Andreas ha stooped working ...any solution????????
You can try running it in Compatibilty mode for earlier versions of Windows and as an administrator.
Feb 03, 2013 | Computers & Internet
MY tv is not getting turned on Manually/ Remotely..!
First if now total dead it has a fuse inside to look at.
Jun 14, 2012 | Venturer 19 inch flat screen TV
Radio stooped working. I bought a new one and it wont work either. I thought I checked to fuses. What fuse powers the radio?
Check all of your fuses. Today's radios require two power sources to work. One constant (to retain memory) and one switched.
Apr 11, 2011 | Car Audio & Video
The speakers of my lenovo R61i laptop have stoopped working
Welcome to FixYa!
What do you mean it stopped working? No sound at all?
Please try the following:
1. Please make sure the sound is not set to mute. Try to adjust the sound volume.
2. Reinstall the audio driver. You can do this using the drivers disc that came with the computer or you can download the audio driver from the computer manufacturer's website: http://support.lenovo.com.
3. Try to connect an external speakers or headset. If you can hear sound on an external speakers or headset then the internal speakers of your laptop is already defective.
Hope that helps. Thank you for using FixYa!
Feb 14, 2011 | Lenovo ThinkPad R61i Notebook - 7732B4U
Constant buzz from the speaker-- unit transmits but does not receive
Mine was doing this recently, i pulled it apart and found there was a small square box, about 5mm square with a plastic circle that can be turned by a screw driver, gently turn this until the unit stoops buzzing and receives.
BE CAREFUL! i was doing this to mine but i turned it too far out, it is not designed to be completely unscrewed, just adjusted slightly. (there is a coil on the inside and this snapped of the connecters below) i don't know what this pare is called but if somebody knows the name let me knowbongbosh@gmail.com
Oct 21, 2010 | Cobra LI6050-2WXVP Two Way Radio
My maytag stooped cooling and does not sound like it is running
Normally we have seen two issues.In one instance the water feed tube or trough stooped the flow of water to the ice maker and this produce a small transient water leak initially and then it stopped working and leaking eventually as the blocked tube did not thaw.
The other issue was ice in the ice maker that lodged in the blades of the ejector and prevented ice production.
Thanks for contacting Fixya.
Nov 03, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Jl w3 stopped working
Take an OHM meter and measure the resistance on both the positive and negitive leads. It should read 2, 4, or 6 OHMS. This depends on the model either a D2, D4, or D6. If you read that reading correctly then see if there is a capacitor located on the the cone itself or in that area. If it is not visible then that would mean that it is located inside of the magnent area.
Mar 15, 2009 | Jl Audio 10W3v2 Car Subwoofer
No Sound
hai
Sep 10, 2008 | Intel Computers & Internet
46 people viewed this question
 Grubhead
Grubhead
