I turn on the amp and there is loud feedback but no sound from guitar. there is a red wire a white wire then a black wire connected to the two but is open on other end?
  • 1,512 Answers
Hi
It very much sounds like you have a broken guitar lead if I understand what you are describing and there is no connection at the other end. Can you borrow a lead from someone elese to check to see if it is.
What sort of feedback do you get, is it like a humming sound?
regards
robotek
Posted on Nov 10, 2008
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
On the hampton bay remote control fan and light module, i do not have wiring diagram. from my ceiling box, i have a red, a black, a white, and a bare copper wire. I think it is because the light switch has...
Unfortunately, Mark it's really not as simple as it sounds, to connect the wires properly. Because of that third red traveler wire for the 3-way switch. Actually, ceiling fans don't work well, when a 3-way switch is involved, because it was designed only for lighting convenience. When the fan is turned on, the other ceiling lights will start to glow, whether they are ON or not..
You would be much better served if you can locate another line to come off of and wire to that. Of course,y you won't have the convenience of a wall switch to operate it. But, that's what the pull chains on the fan are for.
Hope this helped you and thanks for choosing FixYa.
Sep 04, 2011 | Heating & Cooling
Action is a bit high. Everyone is saying the DC16RGTE guitar sounds great and gives good volume. I found the one I have is not loud and it has too much boom. Is there a problem with this guitar?
Make sure the guitar CANNOT "HEAR" the amp you are using. Local regeneration (feedback below the level to sustain full feedback) will give a boom sound like in a cave. If you get near enough to the amp for feedback to build up, you can actually see the string vibrating and building up. The loudness has much to do with the amp you connect this too and the settings
Aug 30, 2011 | CF Martin DC16RGTE Aura Drednought Cutaway...
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Amp wont produce sound when car is on only when car is off it works
Ok do this little experiment when you turn on the car again disconnect the amp turn on wire from the amp. then get a small wire then strip back both ends with a wire stripper only exposing enough for the copper wire to show. then touch one end to the 12volt on the amp and touch the other end to the amp turn on terminal. The amp should come on and the sound should come on. Your problem then is your amp turn on connection is wrong and may be connected to the power antenna wire which may not be able to handle the load and shuts off so I suggest connecting it to the ignition wire so whenever the radio is on that wire will send 12 volts to the amp to turn it on. Sometimes On the back of the radio harness there are two blue wires. One is Blue and the other is blue white. Always connect it to the Blue white cause thats the amp turn on wire. The solid blue wire is the power antennna wire. Also possible the blue/white wire is sending a weak 12volt signal so just connect it to the red wire which is the ignition wire. Dont connect it to the yellow wire because thats constant 12 volt. If you connect it there the amp will always be on and drain your car battery and you might hear big loud buzz sound when you turn off your car.
Apr 07, 2010 | American Pro VS1405 Car Audio Amplifier
Amplifier Screech at High Volume
What you're hearing is FEEDBACK caused by the nearness of the guitar to the amplifier speaker. Always mute it when not in use, or don't move it close to the guitar amplifier speaker when unmuted.
Usually, even though you hear a high-pitched screech, the problem is actually caused by low frequencies, sometimes below the human hearing threshhold (i.e., subsonic) because they are more omnidirectional and thus more easily easily can loop between input (the guitar pickup, especially on a hollow-body guitar) and output (the speaker). The screech frequency is determined by the distance between input and output, determining how quickly the output reaches the input (then loops around through the amplifier). Therefore, reducing the BASS a bit will often alleviate some of the problem.
This is basically the same type of feedback heard when a microphone is turned up too loudly or the mic is pointed at the PA speaker. Avoid those actions and your feedback will be minimized.
Only time and experience will allow you to automatically take actions to avoid feedback. I worked in the San Francisco Bay Area as a manager and sound man for rock bands and several nightclubs for 22 years. My college major was Physics (which includes acoustics).
Keep on rockin'!
Feb 10, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I am trying to hook up an ancient Kenwood KAC-801 amplifier. The original input cable has 1 red, 1 black, then another smaller awg white (1) sharing a common with another small awg yellow. Applying power...
Yes, keep in mind that the amps have a constant power (the large red wire) and need a remote signal to tell them when to turn on/off. This wire connect to a switched 12v from the ignition or radio blue wire (if aftermarket)
Nov 01, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
50 people viewed this question
 Grubhead
Grubhead
