Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
Roxio making a dvd
I'm trying to burn an .avi file to a dvd ....I don't want to do this as a data file. I thought Roxio would convert and burn at the same time. Can someone give me advice...I'd really appreciate it....Thanks
  • 962 Answers
You can get a converter from goldwave .com. It is a free download i believe. the converter is called LAME and it is a good converter not to be confused with it's "name'. Or you can but the whole Goldwave program. It costs only about 50 dollars . you will have it for as long as you want to.
Posted on Nov 10, 2008
Whenever i burn a dvd with Roxio "Easy" CD &
The service packs are trying to stop pirating software.
Not very good software. TRY Nero Express and Power DVD
http://www.nero.com/eng/downloads-nero10-trial.php
Feb 10, 2011 | Roxio Easy CD & DVD Burning
Tip
How to burn avi video to dvd
What's avi?
AVI stands for Audio Video Interleave. It is a special case of the RIFF (Resource Interchange File Format). AVI is defined by Microsoft. AVI is the most common format for audio/video data on the PC. AVI is an example of a de facto (by fact) standard.
what's dvd burner ?
A DVD burner is a device used to encode or "burn" information onto a blank DVD. A DVD is a form of storage media 12 cm (4.72 inches) or 8 cm (3.15 inches) across that can typically hold 4.7 gigabytes (GB) of information, enough to hold a three-hour movie at high quality, or ten TV episodes, or about 75 hours of .mp3 files, or roughly 15 hours of video in the lower-grade .avi format. The DVD is thought of as the successor to the conventional CD (compact disk). Common formats include DVD-R and DVD-RW, a rewritable version of the DVD.
step by step guide on how to burn avi video to dvd
Download Video Converter, install and run it.
Step1. Click "Browse"to import your AVIs in the software. Or select and drop them in! Double click the file name to have an instant preview.
Step2. Click "Edit Profile" to adjust video effects, trim for a video clip and crop for a proper video dimension. Choose "DVD-Video Format( *.vob)", and set the output folder in "Browse".
Step 3: Settings of AVI to DVD Converter.
(1) Click drop-down button next to “Edit Profile” on the main interface to find the suitable quality for your output.
(2) Click “Edit Profile” to open the “Settings” interface to make detail settings for output audio and video, such as audio and video codec, quality, bit rate, video frame rate, video size, audio sample rate, etc.
Step4. Click “Convert” button in the bottom left to start the AVI to DVD Converter, and then burn your VOB files to a DVD or CD for easier carrying. Fast conversion speed!
on Jul 29, 2010 | Computers & Internet
I have a video file on an sd card and when i try to burn it to dvd it says that the file is unsupprted how can i save to a dvd
I think you need to try Leawo DVD Creator to convert your video to DVD format and creat DVD floder and then burn into DVD. After that, you can play in DVD player.
Oct 10, 2010 | Cameras
My asus dvd writer does not make dvd video which play on dvd player
If you're talking about making "Home Video" into playable DVDs it's not because there's necessarily a problem with your DVD-Burner. It's most likely because your home videos are being recorded as .AVI format files. There are some other file formats it could be, but it all boils down to the same problem: the DVDs you make will only play in computers or on the rare chance that you come across a DVD player that plays those formats. The best way to remedy this situation is to buy a program that will convert the files from .AVI to DVD. There are several to choose from. Roxio reportedly has software\programs that will do this. I'm sure that Nero does too. Both companies produce several different versions of "Burning Software" do your research and be sure you buy one that will convert the files for you. There is another one that I've personally used to convert the files and burn the DVDs for me. It's "I'm Too AVI-to-DVD". I know that is an odd name for a program, but it's straight forward in what it's function is. When I used this program to convert the file formats for me and burn the DVDs it literally took several hours to convert and burn about 5GB of video for me. I don't know if Roxio or Nero would be able to do it faster than that. converting file formats can be a lengthy process.
Mar 23, 2010 | Computers & Internet
How can I burn a CD with a movie file to use on a DVD player?
First of all do you have the right kkind of dvd player?
I have a dvd player that plays DIVX movies, so I use Roxio software and burn a data cd of an avi. file. From my understanding AVI, DIVX, & MP4 can be read as a divx. Make sure you close you secission on the disc or it wont play.
Sep 19, 2009 | Panasonic DVD-S77 DVD PLAYER
Roxio burning dvd
I think it will not. The output has a different file name. But don't save the converted file same as the source file. Or you could try experimenting with it using a short avi file then convert it to dvd.
Also are you making its output be automatically burn unto the disc? It will keep its original file.
Mar 20, 2009 | Roxio Easy Media Creator 7
File images
There is no need to convert iso. Better you go to select file and select all the avi file you need to write on the CD/DVD. The files will be transferred on your disc.
Feb 03, 2008 | Roxio Easy Media Creator 7
Convert to playable dvd from .mov file
Usually .mov Files will work if you have a good DVD Burning Program, however the standard is .mpg or .avi. Most programs such as Roxio, Nero, and 3rd party DVD Authoring programs will use any file, but it will take a little longer because it has to convert the video, usually resulting a little quality loss.
Jan 10, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
70 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
