Question about Jandy AQUALINK RS TELELINK KIT
Yard lights will not turn off at time programmed. Have to turn them off manually next morning.
  • 125 Answers
I have a Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU and the pool pump and heater work fine untim the next morning. The pool pump comes on and the heater does not. The service light...
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
May 29, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Hi - My Intermatic T101P3 timer motor stops after it turns off the pool pump. I have one start and one stop time in a 24 hr period. I have to manually start the pump at the timer in the morning,...
Sounds like the clock leads are on the wrong posts, or at least the hot one is. If if was moved to the load side then manually starting the timer will also power up the clock motor. As soon as the clock trips the off timer, the pump and the clock motor are both off. Examine the clock leads to the wiring diagram inside the clock box cover to ensure they are connected correctly. I bet you'll find one of the wires is misplaced.
John
Aug 31, 2011 | Intermatic T101P3 Pool Timer IndoorOutdoor...
I have an aqualink RS8, which controls the on/off timing of the pool/spa, fountain feature, solar heater and yard lights. 1 - the display reads "6520 rev hh" 2 - the spa has been turning on by...
first disconnect the spa side remote if they go away replace the spa side remote if they don't go away go to system setup and go to programs either cancel if all button or delete or edit if one touch or PDA
May 25, 2011 | Jandy Aqualink Rs4 One Touch Control...
I have a Teledyne Laars Mini Therm Copper Tubing Boiler that started to turn on and off several times before it would go back to normal and have the burners light for a while. I called in a tech and he...
The unit may not be recognizing the burner flame is on and constantly rolling back thru the start-up cycle. I am assuming the ignitor is what you mean by "box and wire" the tech replaced so it should be ok. The next step would be to look for corrosion on the terminal the wire connects to, around the plate the terminal itself is on and the ignitor assembly. If the signal from the probe that registers the heater is operational cannot get back to the ignition control module the heater will behave as you describe. There are other suggestions for short cycling found in the manual linked below. You will need to pich your exact model from those shown and roll down to the troubleshooting section.
For more information and/or assistance you can refer to the owner's manual here, contact the manufacturer here, call their tech support at 800.900.9276, or post a comment to this thread.
John
Jan 26, 2011 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
I have two LED color lights in my pool. 1 changes color but the other does not
Your post did not specify the brand of pool lights you have, but assuming they are Hayward, it sounds as though the lights are out of sync... that is, one light is running a different program than the other. If both lights are controlled by the same on/off switch, this is a simple fix; If they are on separate switches you would use the same procedure, but then BOTH SWITHES must be toggled AT THE SAME TIME. To re-sync your lights, turn both lights on and, if necessary, wait for the15-second full-white period to elapse. Next, turn both lights off and wait no less than eleven (11) seconds, but not more than fourteen (14) seconds before switching the lights back on again. Remember... if each light is controlled by a separate switch, then both switches must be toggled "on", "off" and then "on" again at EXACTLY the same time. If the lights are operated in this sequence within the 11-14 second window, they will both automatically revert to full-white light for 15 seconds and then reset to program one. From that point on, as long as you switch the lights on and off at the same time (to cycle through the color programs), they will remain in sync. Good luck.
Dec 13, 2010 | Hayward 12v LED Color Logic Pool Light...
Pool lights go on randomly--not programmed to go on at all
make sure the light is pluged in a port that is for like a spare aux. any time you add programs you must hit the store button.
Oct 05, 2009 | Jandy AQUALINK RS TELELINK KIT
Pentair Mininmax NT natural gas pool heater. Unit has power, water pressure and gas. Display shows correct water temp and the desired temperature. Unit does not switch on either manually or in automatic....
The Dianostic Lights when trying to start the heater is where to go next. When you tried to start the heater manually, did you have your automation system turned off so you can start it manually? If you did, when you tried to start the heater, wht happened? Did you receive any error codes? Were any of the System Indicator lights on? If you open the right hand side door, there will be a part with FENWAL on the sticker-near the top of the heater. Next to the word FENWAL, you should see a small arrow pointing up, there is a Red Diagnostic light above the arrow, is it flashing, and if so, how many times?
If you do not have an Owner's Manual for the heater, follow the link below and it will take you to one online. There are some trouble shooting ideas there also.
http://www.pentairpool.com/pdfs/MiniMaxNTOM.pdf
Jul 01, 2009 | Pentair Pool & Spa
Jacuzzi keeps going to half full of water
This is nothing to be concerned about, manually shut off the pump and watch for water leaking somewhere and fix
Mar 12, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
166 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Richard Roth
Richard Roth
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
