Question about Creative Labs ZEN SLEEK MP3 Player
It Freezes Before It Goes To The Menu
When i was deleting music from my zen sleek it froze while it said "deleting" then i pushed the reset button it started out okay but it keeps freezing in the beginig where it says Zen Sleek !
    President:
  • 4,402 Answers
This is important; because, if you cannot get into Recovery Mode, then this is a sure sign of a bricked player. You could try a forced hard reset by going in and disconnecting the battery, but chances are, the player is bricked.
try updating the firmware.
Posted on Feb 22, 2008
When my wife turned her Zen Sleek on it asked her to reboot, format or reset firmware. She rebooted. It got to ZEN and froze. after about an hour it gave her the same options. She reformatted. Still...
Creative Support
There's support on the Creative site for the Zen Sleek player:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&subCatID=214&prodID=13599&prodName=Zen%20Sleek&subCatName=ZEN&CatName=MP3+Players&VARSET=prodfaq:PRODFAQ_13599,VARSET=CategoryID:213
Considering the frozen problem
Creative gives this information when the player freezes, in the knowledgebase solutions:
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the right of the dock connector port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64128: Accessing the Recovery/Rescue Mode of your Player
    Note:
    1. Clean Up scans a player's hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player's firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009 <<<<<
1.
How to perform a Clean Up:
http://support.creative.com/kb/ShowArticle.aspx?url=http://203.211.142.197:80/srvs/cgi-bin/webcgi.exe/,/?st=183,e=0000000000715959190,k=4557,sxi=12,varset=ws:http://uk.europe.creative.com,case=64128
Player has to be in Clean Up mode.
This is the link SID 64128, viewing knowledgebase solutions.
2.
Performing a format or reload of the firmware , after Clean Up:
http://support.creative.com/kb/ShowArticle.aspx?url=http://203.211.142.197:80/srvs/cgi-bin/webcgi.exe/,/?st=374,e=0000000000715962234,k=4557,sxi=12,varset=ws:http://uk.europe.creative.com,case=63033
Player has to be in format or reload firmware mode.
This is the link SID 63033 viewing knowledgebase solutions.
Manual for the Zen Sleek:
http://files2.europe.creative.com/manualdn/Manuals/TSD/8891/0xCF294831/Zen%20Sleek%20Quick%20Start%20Multilingual.pdf
Just post a comment, when needing more help.
Nov 25, 2009 | Creative Labs ZEN SLEEK MP3 Player
Water Damage, screen freezes, reset means rebuilding library.
http://www.fixya.com/support/r3771170-phone_water_damage
Sep 11, 2009 | Creative Labs ZEN SLEEK MP3 Player
Blank Screen
You tried getting to recovery mode by pushing the play and power buttons at the same time while pressing a pin into the tiny reset hole on the bottom of the player? If not, do that and run "clean-up". It might be able to fix the software for you.
Aug 14, 2008 | Creative Labs ZEN SLEEK MP3 Player
Creative zen sleek
I have this problem also. Can you format the drive and try again?
Mar 19, 2008 | Creative Labs ZEN SLEEK MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Frozen again
There are many causes for the freezes all of which I have found so far to be operator error. Except for the firmware upgrade. Follow all manufacturers instructions for resets and reinstalls (read throughly before proceeding) and all will be well again. We have 2 sleek photos I found the users to main the problem (2-teenages). Corrupt files (pics & audio)cause freezes. Find them and delete them. Regular cleanup from the utilities menu)helps alot these units are mini-computers but they do not multitask well- cant push them.
Aug 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Been frozen for about a week
You have to hit the reset button. You stick the end of a small paperclip or even the wire part from those garbage bag twist-ties into the reset button which is the hole on the bottom of the player. As you push the paperclip into hole you must hold down the PLAY button. This should put it into the Recovery screen or else it will just say "Rebuilding Library". If it goes into the Recovery screen you select CLEANUP and then YES. After it goes through cleanup which can take forever then it will will usually reboot on its own or if it goes back to recovery screen hit REBOOT after you have done CLEANUP.
Jul 28, 2007 | Creative Labs ZEN SLEEK MP3 Player
Zen sleek frozen after trying to delete songs
Why does technology make you work for what you already paid good money for? Have you tried going into Recovery Mode? You do this by holding down the Play/Pause button while triggering the Reset button. Once there, you have four options. Try selecting Disk Cleanup and then Reboot. You might need to re-Sync a few things but it's worth a shot. Good luck.
Dec 16, 2006 | Creative Labs ZEN SLEEK MP3 Player
It Freezes Someone Help Me Please
Oct 28, 2006 | Creative Labs ZEN SLEEK MP3 Player
System locking up, I can't do a thing
Try taking a toothpick, and at the bottom of your mp3 player, there is the usb insert port thing, but then there is this little hole to the right...it's the reset button. After you hit the reset button, just let it charge.
Sep 21, 2006 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
107 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
