The Totaline thermostat up button won't work when it gets colder at night and I try turning up the heat to get my house a little warmer. Its like its locked but the down button works to lower the heat temperature setting. I don't understand what could be the problem I done tried everything to figure it out but haven't found a solution to the problem yet. I was wondering if anyone else out there could help me with this?
Have you removed the Batteries, if this does not work, try put a Meter across the two hot wires and ckeck the Contacts work, let me know, but it might be cheaper to change it, but again let me know
Bobby
I've got a Thermaltake blac X docking station. The blue light comes on but it is not blinking and my...
(More)
I've got a Thermaltake blac X docking station. The blue light comes on but it is not blinking and my comp doesn't see it. What do I do next? This is the second time I used it and it worked fine the first time.
pulled an allied telesyn AT-FH708E net switch from the dumpster, and need to download the user's...
(More)
pulled an allied telesyn AT-FH708E net switch from the dumpster, and need to download the user's manual. Prefferably PDF, definitely free.
When testing long cable runs with the WireView wiremap adapter, the etherscope will intermittently...
(More)
When testing long cable runs with the WireView wiremap adapter, the etherscope will intermittently show shorts and cross connections that do not exist. This occurs whenever the etherscope is connected to the AC adapter. Once the adapter is disconnected, the etherscope functions normally. Any ideas as to what causes this behaviour?
