Question about Presto HeatDish Compact Heater
Bypassing the buzzing mechanism
I read your post earlier tonight. How exactly did you go about bypassing the buzzing mechanism on the Presto heat dish? Currently I have mine taken apart and am REALLY wondering which part controls this! Any solutions? My heater starts buzzing after it's on for only 10 or 15 minutes. Thanks!
  • tumbleweed75 Jan 23, 2009
    SAME AS LISTED
    THE BUZZER GO OFF WHEN TRY GET SOME HEAT -- CAN YOU BY PASS THE BUZZER MODEL HRH316 NO 310-0101-01
  • Anonymous Feb 18, 2009
    I read the posted solution for this problem as well. But I don't have any white wires, just three black and one red. At least two seem to be connected to the buzzer. Can I just cut the wires? The thing buzzes for absolutely no reason, and scares me half to death!
    Problem Solver:
I simply disconnected the wiring and it works just fine.
Posted on Dec 23, 2012
I have no solution. I attempted to repair the noise problem using a post that described how we should by-pass the buzzer. NO GOOD! I am trying to live with this piece of noisy ___p!!!! let me know if you find a correct solution. thanks, jim
Posted on Nov 10, 2008
Anti theft bypass
Have a mechanic install a new ignition lock cylinder with a new key so you can use the car normally without bypassing things. By bypassing the anti-theft then you are making it easier to steal your car.
Jan 12, 2014 | 1994 Buick Skylark
Presto Heat Dish "buzzing" while on and sitting stationary
This question has been answered. I was having the same issue and I can tell you that the solution gregstobbe gave worked for my heater.
http://www.fixya.com/support/t1225707-presto_heat_dish_buzzer
Oct 14, 2009 | Presto HeatDish Compact Heater
My heater is not working on my Supra. Its a 1989 model. I have changed the thermostat but that has not solved the problem
It is most likely the vsv under the hood by the passenger side firewall. Mine would only blow cold air. As soon as I bypassed the electronic vsv vacuum hoses the vacuum switch opened hot water from the radiator into the heater core and presto I now have heat. I found a vsv at a junk yard today and will replace next weekend but for now at least I have heat. Basically the vsv is what tell the vacuum switch how much to open and close to fluctuate the hot water running through the heater core. By bypassing it I cannot adjust the temp. inside the cabin except through hitting a lower blower button. I hope this helps.
Oct 12, 2009 | 1989 Toyota Supra
2002 jetta tdi running lights stay on, cruise control doesnt work
I believe u are not bypassing the correct switch be careful when bypassing u can damage something if u don't know what u are doing
Jul 24, 2009 | 2002 Volkswagen Jetta TDI
Presto parabolic makes loud buzzing sound after a few minutes of
The metal dish must be dust free or it will transfer heat to the safety device. If this is not the solution call customer service at 800-877-0441
Jan 13, 2009 | Presto Like Parabolic Heater Heat Dish
WON'T COME ON AT ALL.
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Presto Heat Dish w/footlight
This heater must be flat on the floor or it will buzz, and the metal dish must be clean or it will transfer heat to the safety device. If this does not solve the problem call customer service at 800-877-0441.
Jun 14, 2008 | Presto Heat Dish/Electric Heater with...
Presto HeatDish
buzz? is this heater an infrared or are the heat coils exposed?
Oct 30, 2007 | Presto HeatDish Compact Heater
Can,t get any music on my mp3
I copyed the below from one of my earlier posts, read the bottom. Good Luck Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Sep 16, 2007 | SanDisk Sansa e260 MP3 Player
Presto HeatDish Compact Heater Logo
693 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
