Question about BenQ FP567s 15" LCD Monitor
Monitor hibernation problem
When my monitor starts up or idles into hibernation mode, black screen and green power light blinking, it will not come out of it. It does this whether connected to a computer or not on powerup. The only setting on the computer that has been changed since this problem began is to disable the sleep mode. I also attempted to connect it to another working computer with the same type monitor as well with no change. On random occasion, it will turn on when the video cable is disconnected and reconnected, but lately this has become so infrequent as to be undependable. At other times, when left unconnected from any source, it will go into a standby mode where the screen flashes solid colors in series. Once it does this, it will turn on when connected to the monitor cable. It does not often or reliably go into this mode either. One last note: the computer it is primarily connected to works fine with several other monitors and this monitor has the same problem no matter what computer it is attatched to.
  • sure19 Feb 08, 2008
    Same problem with my benq lcd...
My lap top will not power up The charging light is on but when I try to start it nothing happens?
Posted on Jul 23, 2008
    Champion:
  • 220 Answers
Dry solder on inverter pcb,Inverter transistors transformers.
Resolder.
Samir
Posted on Feb 29, 2008
I hit mine on the top of the head - a brisk tap to the top edge on the right side wakes it up.
Posted on Oct 09, 2007
Mine does the same( fp567s). Lay screen face down and tap GENTLY fixes mineSuspect loose connection at power board ,too lazy to look
Posted on Mar 07, 2007
Hello when I turn on my monitor and computer this morning I have a black screen on my envision monitor and the green light keeps blinking do you know how to fix this
Unplug everything from the tower. Including power cord.
Press the power button for 5 secs.
Proceed to connect, power line, mouse, keyboard and monitor
That should reset the power or hibernation mode that you might have issues.
If everything looks normal, proceed to connect your remaining devices.
You must be aware that having a BIOS settings to boot from USB, DVD or USB-FLOPPY might prevent to boot into windows.
Feb 24, 2015 | Envision Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
After hibernate mode monitor blinks on and off. The monitor is on power is being feed to monitor however if you turn the power button on and then off the picture on the screen will blink on and then off
If it is your computer that is in hibernation then blinking on the monitor light is normal
Just bring your computer out of hibernation and the screen will come back to life too
Aug 22, 2009 | Dell Computers & Internet
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
BenQ FP567s 15" LCD Monitor Logo
374 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
