Question about Kitchen Ranges
Jenn Air drop in downdraft range convention overn
Parts for Jen
5 Suggested Answers
SOURCE: F1-1 error on Jenn-Air Range
VANMAN69, I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
Posted on Aug 02, 2007
SOURCE: outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Posted on Dec 09, 2008
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
SOURCE: replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Posted on Feb 27, 2010
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn air downdraft
replace parts only. no home fix on these. Depending on model #, the parts may no longer be available, but you can always search on ebay for one.
Aug 18, 2014 | Jenn-Air Kitchen Ranges
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Outside cold coming in thru downdraft exhaust vent
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
1,134 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
