Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Older hobart kitchen aide Supera by hobart KDH7A
I have an older hobart kitchen aide dishwasher. It isn't rinsing well. Need sources for how to fix it or get parts.Need new bottom rack as well
Kitchen Aid Subera KDH7A by Hobart
    Scholar:
  • 109 Answers
If i remember correctly, a KD7 was built in the 70's or early 80's, we used to service them before being sold to Inglis. Seeing it uses the same water solenoids to fill, and asuming it is filling ok, I would suspect worn arms and hubs. If it doesn't fill completely, the fill valve coils may be opening when they get hot from the water flow. The fact that you need a new rack would indicate wear thhoughout and may be too old to justify repair. Find your local Inglis dealer to check on parts availability.
Posted on Oct 04, 2009
Find out why hobart bar aid hood dishwasher not rinsing
A model number would be handy...
Take it the thing fills OK (possibly a bit slowly?)
Unboosted machine look at water pressure/flow (clogged strainer; shared supply; scaled boiler outlet);
Boosted machine look at booster pump (motor dead; impeller broken; capacitor failed)
Feb 16, 2015 | Hobart Dishwashers
My lxi-h won't draw rinse aid through the pump
You need to replace the squeeze tube on the rinse aid pump
May 23, 2013 | Hobart Undercounter/Lxi Warewasher 24"W x...
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
What does add rinse aid and where do you put it kitchen aid dishwasher
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
Jun 27, 2009 | Dishwashers
Hobart glasswasher: code E3, not working, not pulling rinse aid
The error you see is that the dishwashers chemical board (located on the back of the machine) isnt sensing the chemical.First thing to check is remove the lower front panel,2 philip screws.On the left you will see 2 pumps one on top of the other.
They may be marked (det and r/a),turn the dishwasher on these 2 pumps should run.If they dont your pump may be bad or the control board.Run a full cycle to make sure.
If they do run i would make sure the standpipe in the r/a bottle isnt kinked or the tubing.Let me know,i'm a hobart tech.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Rinse solution stays on the glasses
First chech the machine is warming the rinse water and not rinsing in cold water then have your chemical guy come and check that the soap/rinse ad dispenser is not dispensing too much rinse aid and naturally make sure the machine is in fact ricing with water I have had it where a glass washer takes more rinse aid then i should and does not actually rinse with clean watr it was simply spraying the rinse aid wich sounded as if it was rinsing soulution was new pc board it was not changeing programs properly if you have and older machine it proberly has a timer this too can be a cuase of the problm if it is not clicking over to allow a full rinse cycle.Hope this helps let us know.
Jan 17, 2009 | Hobart 29 in. AM15-1 Free-Standing...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
123 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
