Question about Presto HeatDish Compact Heater
Presto Heat Dish buzzer
I've heard some mention, here, about somehow by-passing the buzzer mechanism. After my dish heater has been on for maybe 10 minutes, it starts buzzing (as though you tipped it over). I turn the heat down, and it'll eventually buzz again. How exactly do you bypass the buzzing mechanism? Right at this moment, I have my heat dish apart on the floor in the den and can't figure out which part the buzzer is! LOL
Thanks for any help!
  • tclassy4u Jan 21, 2009
    I took my dish apart to disconnect the buzzer but I have no red wires. i have one black one that goes to the bulb and all the rest are white. the buzzer goes off every 10 minutes no matter what setting it is on. my heater is clean so it can't be becase its dirty. i was given this heater by a friend or else i would have taken the stinkin thing back. does anyone know how to disconnect this buzzer ?
I have no doubt that a previous post meant well with the suggestion to remove and bypass the tilt (or "tip") switch but this a very dangerous thing to do. It costs the manufacturer money to incorporate these safety features. It cuts their profit margin so believe me they wouldn't include them if it wasn't absolutely necessary. To eliminate this switch would disable the unit's capability to not only warn you with the buzzer of an upset condition but also ensure that the element will stay on when lying on it's side on the floor!! The only way the heater "knows" that it has been tipped is from this switch opening up and splicing it's wires directly together will forever prevent the detection of an upset heater. If you fall asleep with the unit on and the pooch brushes past it, knocking it over, it will lie on your nice carpet or wood floor silently cooking anything it touches and the alarm won't sound even when you need it. Don't set yourself up for an easy fire.
The buzzer is wired in series with the heating element (coil) and without the two safety switches it would stay on forever (the round button-like devce at the top of the reflector dish is a temperature high limit switch there to prevent a runaway heat condition). These two switches actually short circiut the buzzer so current will flow only through the heater element under normal operation but if either switch opens current can now flow to the alarm buzzer as well. Since the buzzer adds a lot of resistance to the coil/buzzer path it severely reduces the available shared current to the point where the coil won't heat up but since the buzzer only needs a fraction of what the coil does, it sounds off.
Incidently, that high temperature switch can be tripped off (turning on the buzzer) by a dirty reflector because the dirt or crud spilled on the dish prevents full reflection of the developed heat, dramatically increasing the temperature near the limit switch (as a white surface under the sun reflects heat while a black surface absorbs it). It usually takes a few minutes for this to happen. When the switch resets the cycle repeats. However if the alarm sounds immediately for no apparent reason at start up, either switch or the associated wiring will be open circiut.
Many electrical devices that I have serviced have different sized connectors to prevent mixing up their positions when reassembling but these units use identical sized spade terminals so make sure you note their original locations before pulling them off. Transposed wires may appear normal but cause many and varied new problems. Wires normally are routed to avoid strain so if one looks like it is stretching too hard to reach it's terminal it's probably in the wrong spot.
Posted on Feb 20, 2009
  • Shabnam Virani
    Shabnam Virani Dec 29, 2017
    Thanks a lot for the help, i had same exact problem and all i had to do is clean the reflector dish and it fixed the annoying buzzer. I cudnt get thorough access though. I would like to know how to take apart the dish reflector grill cover ?
  • 56 Answers
For those of you that want to void your warranty or just dont care there is a fix for the buzzer problem.
If you take the three screwws in the back and the one in the top next to the heat selector switch the steel dish portion will come away from the dish back. located on the bottem of the back inside panel there is a small disk looking tilt switch that has one red wire on one end and on the other a white and two black wires. remove this component and all wires from it. take all the wires from it and remove the ends exposing solid wire. for this modification you will need a philips driver wire stripper and cutter and one medium size wire nut available at almost any hardware store. take all the loose wires and wrap them together and place the wire nut on them. be sure to tuck the wire someplace away from the dish portion when going back together. put the unit back together and plug it in and "presto" you have no anoying buzzer anymore and the heater wont go on and off like it used to. this seems to be a comen problem due to lack of insulation and poor design on heatdishes part. hope this solved your problem
Posted on Dec 25, 2008
I already fixed my buzzer issue. I took the heat dish apart and when i didnt see the red wires i started looking at the different little boxes. one box had 2 white wires going to it. i took the manufacture name off the box and googled it and found that it was the buzzer. i actually found a pic on the internet that was the buzzer. i disconnected the little black box that had 2 wires on it and now my buzzer doesnt go off. but on the high setting it still turns off for 5 minutes after being on for 10 but no buzzer. on the med setting it doesnt cut off it just dims down.
  • tclassy4u Feb 20, 2009
    oh and yeah the tilt i didnt disconnect that still works but my buzzer doesnt... : )
Well, I had the same problem with my Presto Dishheater buzzing after a few minutes. After reading the post by Smpthcnerd I decided to take a look for myself.
Maybe I've done something terrible, but I think that there's a simple acceptably safe solution. The limit switch (button) at the top of the dish can be shorted by just using a straight metal bit to connect the two wires the enter and exit the limit switch. Just modify a standard electrical connector.
This keeps the tilt alarm alive, but eliminates the false overheat alarms that I was getting after about 5 minutes of operation. The heater thermostat works as normal--just cycles on and off depending on where you set the top dial.
By the way, be careful about how you place the shorted lead assembly. I taped them with good quality electrical tape and rigged them so that they are positioned in a relatively cool location behind the dish. Then I checked it after 15 min of operation to make sure the temp wasn't affecting the new wiring. You don't want the leads to short to the dish housing, needless to say. So be careful about that.
Let me know if I missed something, safety wise. It appears to work like it should, with the tilt alarm intact and the thermostat as well... My problem was a faulty limit switch that was causing the buzzing. Presto doesn't sell repair parts for the HeatDish, so wiring around the fault was the only solution I could think of. If your problem is different, then this approach will not be effective.
Good luck and stay safe.
Posted on Dec 06, 2009
  • Siclmn Nov 03, 2012
    You don't use electrical tape on a heater. It will get hot enough to just melt off.
Set the unit on a flat surface greater than the base and it works fine!!!
Posted on Mar 08, 2010
  • Rupert Steffler
    Rupert Steffler Oct 02, 2017
    Clearly it doesn't or the guy wouldn't be here you genius
    New Friend:
I knew that I would not want to remove the alarm because of the intended purpose of notifying me if it was tipped over.
I wanted to see if dust or dirt could be triggering the alarm to go off. I removed the the screws and opened up the back. I located the alarm towards the bottom left side. I wiped and cleaned the whole inside surface in the back and then got out the vacuum and vacuumed around the alarm. I also used the long thin vacuum hose attachment and vacuumed the front heat coils'.Their is no need to cut the metal frame in the front of the unit to reach the coils. The heater works like a champ again.
Posted on Jan 28, 2016
    New Friend:
I put a wet paper towel and used a pen to move around the towel in the dish and cleaned all dirt; now it's nice and quiet!
Posted on Dec 17, 2012
How to clean the dish?
Just snip out some of the wire grids and now your hand fits through.
Posted on Nov 03, 2012
  • Siclmn Dec 17, 2012
    If you do this never put your hand through it when it'
    is plugged in.
JUST CLEAN THE INSIDE AND OUTSIDE OF THE DISH....I USED A DAMP HAND TOWEL AND HAVE FIXED 2 SEPERATE UNITS......THE DUST SETS OFF A TEMP SENSOR.
GOOD LUCK
Posted on Mar 05, 2010
  • Claudia Salinas Nov 22, 2011
    How do you clean the inside of the dish? Do you take it apart? If so, how do you take it apart?
I put a fan on the lowest setting, place it right next to the temp control pointing the fan so that it blows as much away from the heat dish as possible. For my own added security I place a fire alarm on top of the box fan I use. Or place it some where I can predict the smoke to go first . Something else I have used is an auto timer at the plug in. Set it to turn off every 30 min. And back on. It's not a complete solution but it does work. What ever solution you choose I wouldn't leave the dish on when I'm not home or even unattended is risky if you ask me
Posted on Dec 27, 2011
My dish does the same thing, I just turn the knob to "off" every 6 minutes and turn it back up a second later. that way it cools down and doesn't give you a heart attack.
it's not a complete fix, but at least it doesn't involve taking the thing apart!
Posted on Feb 08, 2010
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
RE: Presto Heat Dish buzzer going off
I almost threw my heater out! I cleaned this morning with Window Cleaner and it works just fine now. It was just dust. I cleaned the round metal area not the coils.
Hope this helps.
Emailed Presto about replacing the buzzer and here is the answer I got:
There is no such part. Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Jan 11, 2010 | Presto HeatDish Compact Heater
My heater makes this constipating noise and the "tilt" alarm goes off after 10 minutes. I'm never able to turn it to the high position.
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Dec 12, 2009 | Presto HeatDish Compact Heater
Presto Heat Dish "buzzing" while on and sitting stationary
This question has been answered. I was having the same issue and I can tell you that the solution gregstobbe gave worked for my heater.
http://www.fixya.com/support/t1225707-presto_heat_dish_buzzer
Oct 14, 2009 | Presto HeatDish Compact Heater
Turn headlight arm off and buzzing sound under the hood
change the part that its not comfortable in yore buzzer
May 02, 2009 | 1993 Honda Accord
Bypassing the buzzing mechanism
I have no solution. I attempted to repair the noise problem using a post that described how we should by-pass the buzzer. NO GOOD! I am trying to live with this piece of noisy ___p!!!! let me know if you find a correct solution. thanks, jim
Nov 10, 2008 | Presto HeatDish Compact Heater
Presto heaters
We have one in our office where our entry is pretty close to teh main door. It used to buzz all the time after being on for maybe 10 minutes. One day I got sick of it and took a cloth and some windex and cleaned the reflecting dish, and that actually stopped it
Oct 29, 2008 | Presto HeatDish Compact Heater
Presto HeatDish Problem
I rewired my heat dish. I UNPLUGGED THE HEAT DISH. I loosened the three screws on the back and removed them. Then I unclipped the dish at the bottom. The dish should be loose and the bottom section of the dish should be detached from the plastic casing. Look inside the casing at the bottom. There is a red cable attached to the buzzer (it’s the silver metallic piece). Detach the red cable from the buzzer. Now look directly behind the buzzer is a black wire that connects to the circuit next the buzzer. Attach the red cable to the female receptor foot the black cable. Plug it in and it should work fine. This will permantly disable the buzzer, SO YOUR HEATDISSH NOW LOINGER HAS A WARNING SYSYTEM. IF YOU TURN YOUR HEATER OVER THE BUZZER DOES NOT GO OFF, THE BUZZER ALSO INDICATES OVERHEATING OF THE UNIT. SO BE CAREFULL. MAKE SURE THE UNIT IS UNPLUGGED WHEN WORKING ON IT. GOOD LUCK AND BE SAFE
Oct 19, 2007 | Presto HeatDish Compact Heater
Presto HeatDish Compact Heater Logo
10,940 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
