Question about LG LRM1230W Microwave Oven
Would not heat, now outside gets hot
The microwave stopped heating. Then my Dad was turning the carosel back & forth & heard a click. Microwave started heating again, but know the sides of the outside of the oven get hot. Is it dangerous to us it now?
  • Anonymous Nov 17, 2008
    Does not heat
  • 905 Answers
Yes! , this is dangerous , be cause it sounds like the magnetron that sends out the microwaves may not be controlled , thus heating the outside and will be sending waves out of the microwave!
you will need a qualified electronic repair shop to deal with this, these microwaves are very dangerous and that unit should not be used untill it has been fixed , for the safety of you and anyone who uses or is around when in use.
these microwaves that are sent across the air to heat the food is burning it and it can do the same to you or any one who is around it while in use
even when in working normal conditions the waves still leak out some , so i always walk away when heating food in the microwave and i advise others to do the same
so the magnetron will need replaced and maybe another component but it needs to be tested to make sure nothing else is damaged also
hope my help has pleased you and that you can give me a fixya rating( all others hurt our rating) as i work on these and i know the symptoms that happen and the causes
again hope you can give me the fixya! , thanks , and if you need any other help, just ask me!
electech
Posted on Nov 10, 2008
  • jason Nov 10, 2008
    I guess you were not pleased with my help, sorry but that is whats wrong with it
I have a R-8520 Sharp carosel microwave. Previously the convection stopped working, now it does work but heats up too much to the extent that fumes come out from the back of the microwave and it smells of...
I think it might be a good idea to consider having the appliance replaced, the unit is a fire hazard and judging by the burning smell it is on the way out.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
Dometic microwave model dotr12cb runs but does not heat
The most likely cause is the magnetron or the inverter board, if the microwave was manufactured 7 years or less. It is cheaper in most cases to replace the microwave oven.
Jun 13, 2012 | Microwave Ovens
Oster microwave OM1101NOE wont heat light comes on and carosel turns
There are a few possibilities, magnetron, high voltave diode" sometimes cracks" high voltage capacitor " shorts"
Mar 08, 2012 | Oster OGB61101 Microwave Oven
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Comes on for 5 Secs
Hi I am Vortash sounds to me as if the Magnetron is burning out and the heat sensor switch is turning the unit off as the mag gets hot ? .. you can get a cheap replacement of ebay but to be honnest microwaves are so cheap now you will probably get an oven for what you would pay for a new magnetron .. Regards Vortash
May 20, 2009 | Panasonic NN-S262SF Microwave Oven
Microwave does not heat food or liquid
I hate to tell you this but your magnetron may be shot. Its the part that actually makes the microwaves. The best thing I can recommend is get a new oven, magnetrons are expensive and not easy to replace.
Mar 20, 2009 | GE JVM1650 1000 Watts Microwave Oven
Outside caseing heating up while cooking`
Also, Please reply back with your brand and model number so we can help you.
Nov 20, 2008 | Sharp R-1480 Microwave Oven
Emerson Microwave MW8102ss
check control panel, may be problem at control circuit.
Aug 13, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
LG LRM1230W Microwave Oven Logo
277 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
