Question about SAMTRON 55V 15" CRT Monitor
How to clear control lock
I have problem with control lock whenever i open the system it blinks with red colur table on center of the screen with control locked after 15 to 20 mts it gone automatically how to solve?
Replace the 5volt regulator ic, LM7805, location IC602..
Michael Sathe
HCL Infosestems Ltd.
Posted on Nov 10, 2008
No sound on ipad
1. If you have no sound at all, even in the Music App, try rebooting the iPad.
Reboot the iPad by holding down on the sleep and home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider if it appears on the screen - let go of the buttons. Let the iPad start up.
2. If you lost sounds for keyboard clicks, games or other apps, email notifications and other notifications, system sounds may have been muted.
System sounds can be muted and controlled two different ways. The screen lock rotation can be controlled in the same manner as well.
Settings>General>Use Side Switch to: Mute System sounds. If this option is selected, the switch on the side of the iPad above the volume rocker will mute system sounds.
If you choose Lock Screen Rotation, then the switch locks the screen. If the screen is locked, you will see a lock icon in the upper right corner next to the battery indicator gauge.
If you have the side switch set to lock screen rotation then the system sound control is in the control center. Swipe up from the bottom of the screen to get to control center . Tap on the bell icon and system sounds will return.
If you have the side switch set to mute system sounds, then the screen lock can be accessed in the same manner as described above.
This support article from Apple explains how the side switch works.
http://support.apple.com/kb/HT4085
3. Try cleaning the dock connector opening of the iPad with a soft brush and just a little bit of rubbing alcohol.
4. Reset all settings. Settings>General>Reset>Reset All Settings.
Aug 12, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
Console is frozen on connect controller screen
Have you plugged your controller into the system via a usb cable? Do that and hold the center button (PS) until the red lights in front of the controller go from 4 blinking lights to one, then you should be good to go.
Nov 03, 2013 | Sony Playstation 3 (PS3) Console
What does it mean when your laptop's power lights flash ? Including the power button?
"The following table illustrates the meaning of blink codes used on some notebooks with EFI environment.
The blink or beep codes on your computer may have different meanings. When you contact HP for
support, the agent needs to know the model of your computer and may ask you about blinking LEDs
or beeping tones to help troubleshoot a startup problem.Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError Condition
Continuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
1time---Caps Lock/Num Lock-----CPU------------------CPU not functional
2time---Caps Lock/Num Lock-----BIOS----------------BIOS corruption failure
3time---Caps Lock/Num Lock-----Memory-------------Module error not functional
4time---Caps Lock/Num Lock-----Graphics--------------Graphics controller not functional
5time---Caps Lock/Num Lock-----System board----------General system board failure
6time---Caps Lock/Num Lock-----BIOS-------------------BIOS authentication failure
Continuous blinkAC power adapter LEDPower adapter Insufficient power"
Nov 01, 2012 | Compaq Computers & Internet
1992 Pajero 4wd system attempts to engage randomly, 4wd indicator lights blink
Whenever this warning light or any other stays on in the dash it is indicating that the systems control module (or the system sensor in the case of lights like low oil pressure, door open indicators etc.) has detected a fault, it then disables the system (this applies to ABS,TCS, TCM, SRS, TPMS and BCM faults and others) as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System
Oct 31, 2012 | Cars & Trucks
I need to know how to get to Table Set on the TI-85 because I need to find the x intercepts on the graph, but I can't find it. How do I get to it?
try this one:
(first). Set up a function in the TI85. how?
Step 1. Press the [Y=] key to open the function editor.
Step 2. Type in the function you want in the Y1= line.
Step 3. Press [2nd] [QUIT].
(second). Create a table of numbers using the Y1 function.
Step 1. Press [2nd] [TBLSET] to open the table setup menu. On the line "Indpnt", highlight "Ask" and press enter. On the line "Depend", highlight "Auto" and press enter.
Step 2. Now press [2nd] [TABLE] , type in a value for "X", and press [ENTER].
Step 3. Continue typing more values for X to fill up the table.
(third). How can I see more decimal places for the numbers in a table?
Answer:
Step 1. Use the arrow keys to move the highlight over the number you are interested in seeing to more decimal places.
Step 2. Read the number at the bottom of the screen. You should be able to see anywhere from 9 to 14 significant figures for your number.
(fourth). Delete the numbers in a table by:
(The following procedure will work when the table setup has been set to ask for the values of the independent variable.)
Step 1. In the table screen, check the bottom of the screen to make sure that the cursor is not blinking at the bottom of the screen. If the cursor is blinking, press the [ENTER] key to stop the cursor from blinking.
Step 2. Use the arrow keys to move the highlight to the first number in the first column of the table (the "X" column).
Step 3. Press and hold the [DEL] key to delete the numbers in the first column of the table. The entire table should become clear with this procedure.
Thanks! I wish it can help you..
Feb 16, 2011 | Texas Instruments TI-85 Calculator
Playing any PS3 game and screen goes blank. red light on console blinks.
Common reason is your PS3 has overheated. Turn off system after removing game disc and let system cool. Clear any dust or debris from the vents and if possible, relocate PS3 to more open area.
Oct 28, 2010 | Sony Playstation 3 (PS3) Console
It says system error E100
l thing you have trouble in motor section
Feb 17, 2009 | Canon PC-1060 Black and White Copier
My D & E drive is not opening on double click.
parental control pin codes for the box so the new codes can be installed
Dec 28, 2008 | Computers & Internet
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
SAMTRON 55V 15" CRT Monitor Logo
135 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
