Back to:
Tags:
Jenn-Air JMC8130DD 1000 Watts Microwave Oven
Oven and microwave combo (by 2 users)
posted by campy on Oct 28, 2006
while oven was self cleaning, microwave was in operation heating food and stopped. it is completely dead,no light inside and no display.oven is functioning and light inside is on.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by momena, posted on Nov 05, 2007
I am having the same problem. When I was self-cleaning the oven, I used the micorowave oven. It worked fine and right after that, I see no lights, nothing. The oven is fine though. Please let me know how to fix it.
Best Solution
posted on Jan 04, 2008
Helpful (85)
whirlpoolbad
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
Your microwave is plugged into an outlet built into the top of the oven. This outlet has a "circuit breaker" that trips when using the self cleaning feature. This is a design flaw that Jenn-Air/Whirlpool refuses to acknowledge. You just need to reset the breaker button that the microwave is plugged into. It's right next to the outlet.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on oven and microwave combo:
I don't want to Accept this solution
Solution #2
posted on Oct 28, 2006
Thanks for Trying (70)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2980 votes
Fuses and circuit breakers imediately come to mind as the first things to check.
Thank You!
Solution #3
Not Rated (0)
momena
Rating: 0%, 0 votes
Thank you for the suggestion. I got this fixed by calling JennAir. They first thought it was the powerboard inside the unit. After replacing it, still they problem was there. Eventually they figured out that it was the plug in the outlet that got blown away. So they replaced it. As you mentioned it, getting to it was an ordeal. The unit is heavy and they had to get one more person to help them. I paid about $165 for the service. Anyway, 3 weeks after it got fixed, the problem reoccured when I was using the oven and microwave at the same time. So they had to come again and fix it. I hope it does not happen again. I already complained to JennAir about this faulty issue.
Thank You!
Can you Help with these Microwave Ovens problems?
Microwave Ovens
need electrical schematic for sharp model#r-820bc...
Microwave Ovens
the door handle broke off of my built in microwave ...
Microwave Ovens
selecting program but not functioningonn
Jenn-Air JMC8130DD 1000 Watts Microwave...
I'm having a problem getting the oven to self clean. Its...
I have a gas-electric grill-range with convection...
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
