Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet is eating small articles of clothing!
Tonight my machine stopped running toward the end of a normal wash cycle.  It flashed an  "F" code followed by "02" several times.  I cancelled the cycle and then opened the door.  I noticed that the stainless steel drum seemed to be sagging down, and then I noticed a piece of fabric stuck between the drum and the plastic (?) liner on the door.  I found a sock stuck in the middle.  I then pushed one of my hands into that space and after digging around, pulled out no less than SIXTEEN small articles of clothing (i.e., socks or smaller).  All of them were badly discolored (dark gray, basically).  What is causing this and will it continue to do this?  Is there a solution?
  • 5,911 Answers
Okay...first of all, the "F02" error code is a Long Drain error. This is usually caused by debris clogging the drain pump. There is a drain reservoir that needs to be cleaned out periodically. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Keep in mind, it does not take much to damage these small drain pumps. If anything has been left in the pump for a significant period of time, it can damage the pump motor or impeller. The result: a drain pump that "appears" to be running, but may not be pumping anything. If the error code returns, you may have to replace the drain pump.
The socks getting lodged in the rubber door boot can be a common problem. Well...I should say, its not uncommon for this to happen. Due to the design of the rubber folds in the door boot, it can often collect small items. Sixteen socks is not a new record. I found over 20 one time! This rubber door boot must be inspected after EACH wash load to ensure items do not get stuck there. This can result in articles of clothing beginning to mildew and smell over a period of time as well. There are also small drain holes in the folds that help drain away some of the residual water. If these holes become clogged, water will stand in this area and begin to smell. The following link explains the recommended steps to keep this area clean:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
In addition, it is not unheard of to have small articles of clothing (such as socks, underwear and wash cloths) to manage to work their way between the inner spin basket (stainless steel tub) and the outer tub shell and get lodged in the drain hose. I would recommend you inspect the drain hose that runs from the bottom of the wash tub to the inlet side of the drain pump for obstructions as well. I have found wash cloths stuck in this hose that prevented the tub from draining. For future reference, use garment bags for washing small items. This will prevent some of the problems from reoccuring.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 12, 2008
My mass 6 Bosch washing machine is locked up and was blinking in red light letter F what do I do
"Sd" - (Excess suds)
F8 followed by E1 - (water supply error)
F9 followed by E1 - (drain pump system error)
F5 followed by E2 - (door will not lock)
F7 followed by E1 - (motor drive error)
"rL" - (remove load)
Washer making error beeps - Door has not been opened and closed for at least 3 cycles
Washer beeps when HOLD TO START is touched - Door not closed
F# E# code other than as described above appears in display - System Code Error
"nt" (interrupted) - Cycle was paused or cancelled
Clean Washer LED flashing at end of wash cycle - The washer has run 30 wash cycles and is indicating a reminder to run the Clean Washer cycle https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load
Sep 21, 2017 | Bosch Washing Machines
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
I receive an f 02 error on delicate cycel and it won't finish the load
Hi!
Error F 02 means the drain time is taking longer period then normal. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed. To resolve the issue you are facing with you need to follow these steps---
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the ‘sud’ error will be displayed, then 4 minutes later the F/02 error code will be displayed.
To clear this error code—
Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
If still the error code exists then you need to replace the pump.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
Jul 19, 2009 | Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Ultra...
Stops washing cycle without draining and spinning: gives error code F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 20, 2009 | Kenmore Elite 45986 Front Load Washer
F flashing followed by a 2
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clean light flashes 7 times
try doing button setting change from "Hi-Temp Wash - Normal - Hi-Temp Wash - Normal" sequence of button selections. This must occur within 6 seconds and initiates an internal diagnosis of the machine.
The process runs for about 19 min. and shuts off
During the process several LED's light up and several funtions start and stop.
If the machine has no broken systems, you should be able to open the door add some soap and the usual dirty dishes and carry on with normal operation. this is the method to reset the machine.
Most likely is that there were suds in the last cycle or the door doesn't close smoothly.
Jan 09, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
The time remaining on the wash cycle is blinking door is locked
M duet was also haveing problems and when it would stop in a cycle it would flash a leter and a # F 02 I hit cancel and restarted it the time was all messed up I looked up the code for F 02 and found this page, I will post the link below. it was a drainage problem I cleaned out a trap in the pump really easy to do and it just might fix your problem. Regardless ever Duet owner needs to know this and matain this trap I pulled out a bowl full of stuck in it. Good luck!
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Dec 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
951 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
