Question about Canon Office Equipment & Supplies
My computer crashed and we got it fixed but now the printer isn't installed and we don't have the disk
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    What operating system are you using and what model printer are you trying to install?
    President:
  • Canon Master
  • 1,314 Answers
Go to the manufacturer's website and download the drivers and install them manually. Since you didn't leave a model name, I can't find it for you but you can go to the support & driver's section of your printer brand's website.
Thanks and please take a moment to rate as fixya.
Posted on Nov 10, 2008
Our old computer crashed and when I installed Dymo on our new computer, the label size we always used isn't installed. I need label size 30336. Can you help?
I just looked through all the preconfigured labels on my Dymo 330 and did not see a 30336 label. Is it possible you configured this manually or had it inserted from some other program you loaded? It's easy enough to configure a label manually. You might also call Dymo tech support.
Jul 18, 2011 | Dymo LabelWriter 330 Thermal Printer
Fitted refill cartridges to my cannon160 printer and computer crashed
you might be suprised to know that the two actions are not related, safe to say your computer might have been giving some sign of crashing or in most cases, none. When a system crashes, it's the hard disk that has failed and not the entire system. Based on the rate of damage, it can either be fixed by formatting and running a fresh copy of the operating system or replaced with a new hard disk. Either way you should see a technician, Now that you know what the problem is.
Hope this helps
pls rate or vote this :-)
Jul 05, 2011 | Office Equipment & Supplies
How to connect mfc-5840cn printer with laptop
Not sure if your answer is correct, As I said Windows update thought it was downloading the correct driver and it didn't work correctly. I don;t want to say your link isn't helpfull, But I followed another suggestion and installed the Windows Vista Suite for the Brother MFC-5840CN all in one.and it not only fixed the problem it also installed all the multifunction drivers and software.So I am good for now. Thank you for responding to my delema. In case someone else needs it, Here it is.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc5840cn_all&dlid=&flang=English&os=74&type2=-1
Jun 30, 2011 | Brother MFC-5840CN All-In-One InkJet...
Need to reboot i can't even get to the start screen, it keeps telling me to put in a disc.. i don't have a disk drive
This error means that your hard drive isn't functioning correctly. The computer is attempting to load the operating system off your hard drive but the computer can't find the operating system. There are several causes for this problem:
1. The hard drive has crashed.
2. The boot sector and/or operating system has become corrupted.
3. The hard drive has become disconnected from the laptop; this is unlikely but possible.
To determine what has happened follow these instructions:
1. Turn off netbook and remove all usb devices.
2. Turn on netbook and press whatever key enters the boot menu; often it is ESC or F10 - look on the first screen you see when you turn on the computer.
3. Look at the possible devices listed that you can choose from. If the hard drive isn't listed, then your netbook isn't detecting the hard drive likely because it has crashed. At this point you're going to have to take the netbook to a repair shop.
4. If your hard drive is listed, then it's possible that the hard drive is fine but that the boot sector has become corrupted. If you have access to a USB CD-Drive and a Windows installation disk or have a way to create a bootable USB flash drive, then there are some solutions that can be attempted. If you don't have access to these things, then you will have to take the netbook to a repair shop.
If you do have access to a Windows installation disk or can create a bootable USB flash drive, then post back to this solution and I can help you further.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 12, 2011 | Coby NBPC1023XPBLK Netbook PC
I had a major crash with my laptop and have reloaded software for xerox pahser 3200mfp printer. All functions have downloade correctly accept the print function, which when dowloading brings up system...
try to install your printer in another computer if you can install it successfully then the problem is on your laptop hard disk .There might be a bad sector on it try the scandisk of your computer then enable the automatic fix bad sectors.once it is done re install again the software of printer..good luck
Apr 09, 2011 | Xerox Phaser 3200MFPB Multifunction...
After my computer crashed and then got fixed it
hi
you would have to reinstall the drivers for the printer again
if you have the original CDs that were given with the printer try installing using them else try the weblink
http://supportapj.dell.com/support/topics/global.aspx/support/product_support/en/product_support_central?c=in&l=en&SystemID=PRN_ALL_A940&cs=&s=gen
cheers
Jun 23, 2009 | Dell A940 All-In-One InkJet Printer
Need the installation disk
hello,
Ok try to hook and see if the system install it without a installation disk.
If this not resolve, then you have to find driver at lexmark websites.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
may this help.
melnavz
Jan 23, 2009 | Lexmark X6570 InkJet Printer
X6570
printer did work with computer before it crashed.
Oct 19, 2008 | Lexmark X6150 All-In-One InkJet Printer
Computer crash and I lost all to my hp 340 all in one
if it's an HP then go to
hp.com
drivers and download
Aug 20, 2008 | HP Deskjet F340 All-In-One Printer
18 people viewed this question
old marine
old marine
