Question about Husqvarna Daisy 310
Needle hitting metal Husqvarna 33-10 ?
I have very old model Husqvarna as per pic. I had a bad cotton jam and had to remove the casing underneath that the bobbing holder sits in. I notice it has 3 markings stamped on it which look like crowns. How do I align this to replace it back into the machine. I did it once by fluke but can't get it right this time and the needle is hitting metal.
Thanks
Jean
    Novelist:
  • Husqvarna Expert
  • 371 Answers
I'm not familiar with this model. I'm assuming this has been resolved. If not suggest taking it to an authorized husqvarna viking dealer for assistance. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
Insert bobbin holder
check your manual to see how it is sitting in the machine there should be a little catch if you look down where the holder goes just drop it back in again look at the pic in the manual
Oct 14, 2014 | Janome Sewing Machines
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
I have a janome 1 step sewing machine and it keeps jaming. I have been sewing a thicker fabric recently with no problems, but now it jams after about 3 revolutions. I think something is wrong with the...
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, I think yours has a top loading bobbin inside a magnetic bobbin case so this info should work for your model. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room to work).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.tally_girl_3.jpg
Apr 13, 2011 | Sewing Machines
When the machine starts the bobbin shifts, instead of stitching it jams. I have tried to replace it but I don't seem to be having any luck. Elna 6003 quilters dream
Sounds like the bobbin case has shifted inside the rotary hook area. Have you got the manual? if so, does it give directions to remove the bobbin case as part of the cleaning instructions? If you have never taken it out, perhaps take pics with your digital camera to help you put it back in correctly. It is held in by a magnet underneath it. Remove the needle plate, pressure foot and needle, and the bobbin.
Have a good look at the bobbin case, it should have a stopper which sits against a little bump and might have two red marks to line up correctly. Are these lining up or has it shifted a little. If so, then lift out the bobbin case by holding the edge closest to you and lifting it upwards and towards you. Brush the underneath area out carefully to remove any lint or thread bits with your little brush bringing the lint out of the area and into a bin (dont push it around into the area under the rotary hook) and don't blow it out with air. Have a good look at the bobbin case too and check it for any damage, if you dislodge it while stitching the needle can strike it and as its plastic there may be little marks or bits of plastic now, if so, give them a gentle rub with fine grade sandpaper (away from the machine works) or a nail file to smooth off. I found that mine had a couple of holes and the thread was then catching on the rough edge of plastic and jamming constantly. I actually bought a new bobbin case after 3 goes to sort this out.
Now put the bobbin case back into place, lining up the red marks if it has them. Manually turn the flywheel towards you through a stitch sequence, the holder should sit still while the hook goes around it.
Reassemble the machine, rethread and test sew. I hope this helps, if you have tried all this already, then perhaps take it to your Elna dealer for further investigation/service.
Apr 05, 2011 | Elna Quilter's Dream 6003Q
Bobbin case making noises and bobbin thread keeps breaking the material also pukkers up underneath
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, it looks very similar to this Elna so I'm thinking its the same design bobbin and race. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room).
Mar 07, 2011 | Elna Xplore 8600 Computerized Sewing...
The thread seems to be getting caught under the plate on something.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've damaged it badly.
tally_girl_0.jpg I hope that this helps you out, good luck with your machine.
Feb 17, 2011 | Elna 7200 Computerized Sewing Machine
Husqvarna Plantinum 755 model I removed the bobbin case holder to clean because the bobbin tread was bunching up and pulling the material down below thw feeddog and stalling. Why did it do this? now I not...
I would take it to my dealer and have them check it, the last thing you want to do is sew with anything that is not in line. You can wreak all kinds of problems, ask my sister.
Sep 26, 2010 | Husqvarna Sewing Machines
Bobbin Case Popping Out
I had the same problem with my singer 20u professional. I tried to find the answer here but no help but I made a call & she said the bobbing might be too big fer the bobbing holder. the bobbing holder is the round metle thing that fits in ure machine. u have to make sure the bobbing ( the thang that holds the thread is the exact same size as the bobbing holder. Hope this helps.
Dec 05, 2008 | Singer 7422
Machine not working
I had this happen the first day I got my machine. The bobbin case has probably came loose from the holder. There is a step by step cleaning instruction in the manual and it tells you how to reset the bobbin case in the holder in the manual.
Nov 15, 2008 | Husqvarna Viking 1
Sewing Machines Logo
729 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
