HELLO, just bought a fender HRD 410 AMP AND DISCOVERED THAT THE REVERB DOES NOT FUNCTION ! WHAT'S UP ?
  • 1,512 Answers
Hi Fenderman.
Damn, you gotta hate that. First thing, do you have any recourse with the outfit you just bought the amp from? I guess not if you are asking in here. There is not a whole lot that stops the reverb in these amps. First things to check would be that the connections to the rev-eb tank are ok, and the cables to them not damages, and the terminations to the RCA plugs are good. Check that the reverb tank is connected thew right way round also. If everything so far checks out, and yourself, or an electronics savvy mate then time to download the circuit from here
Then from there, pull the chassis out of the box, and check/look for dry/cracked solder joints about the reverb Pot, I would check the voltages about U2, TL072, and even just change it out if you are unsure. The reverb tank could also be down, hard to check this easily without swapping it out, if you have(maybe time for the repair shop here) a CRO, then you can sniff off the audio going in and out of the tank to be sure that is it functioning.
Anyway, that is a rundown on what may be wrong with the HRD. If you have any questions, more that happy to answer them and continue to help you out. a FixYa rating is a great reward for my time to talk this through with you. Cheers!
regards
robotek
Posted on Nov 10, 2008
I have a '93 Fender Blues deluxe tweed and don't seem to have any reverb, am I missing something?
Check the connection to the reverb tank (rectangular box usually sitting on the bottom of the amp). There are a pair wires that connect it to the amp. If wires are connected, and the reverb is not working, you may need to replace the reverb tank.
Oct 16, 2016 | Fender Music
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Reverb wont work !!!!!!! Hot rod deville 410
probably a bad reverb tank. there is a little inductor inside that shorts out easily/common. you cant repair it. its just easier to order a new tank. what you do to test is........turn on the amp with the reverb turned up all the way........ volume up on the amp at normal playing level.....then tap or knock on the reverb tank itself......if you get sound then the output of the tank is good/ no sound the ouput side is dead.......then what you do is unplug the ouput of the tank and plug the output wire to the input of the tank and tap/knock on it again....if you get sound then the input side of the tank is good/ no sound is dead. this is a way to test the tank independently from input to output. which side is bad is irrelevant, what is improtant is determining if the tank is toast. i can get accutronics tanks from my distributor at a better price than anywhere else. email me thru my contact page on my website with the tank code numbers and letters so i can get you a price also check my price with whats on ebay, etc. my website is yostamplifier.com
good luck
Feb 07, 2010 | Fender Hot Rod Deluxe Guitar Combo...
HRD Issues...
Try this article first for some ideas. http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165.
Aug 02, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Peavey bandit 112 reverb
It might just be the control knob. My fender's reverb went out and it was just the knob.
Mar 23, 2009 | Audio Players & Recorders
Fender reverb mod both channels
Go to http://www.silvertoneamps.com/micKfender/Fender-Reverb-Both-Channels.html
there is info on this mod. heed the warnings of hot rod activities!!
There is a solution to your misguided nods you mentioned earlier.
Dec 16, 2007 | JBL Control 23 Speaker
62 people viewed this question
 Grubhead
Grubhead
