Question about Gigabyte GA-8I915G Pro Motherboard
Error on my screeen
Dear Sir,
When i m working with my pc after open 3-4 programe its going to be blue screen and give me "physical dump memery" message appear on my screen and i after that i must have to restart pc ..this problem comming while 3-4 enternet site open then also problem comming..
i don't under stand what the problem is that..
while i work only 2-3 prog.or see any 2-3 enter net site then pc working normal..
i recleanded my ram too..but problem is running..
i load only 10-14 programe....
my pc configuration:
model:-dell optiplex
cpu:-core 2 duo 2.33ghz
ram :- 1 GB DDR2
hdd:-80g sata
pls give me solution ...
  • jason May 11, 2010
    how much free space do you have ? have you added any new hardware ?
    Novelist:
  • 93 Answers
To solve this, I need a little more information. On the lower part of the blue screen, there is an error code you need to write down and post here. It will look something like this:
0x0000000A
That code, particularly the last 3 characters, will give a clue as to what part of Windows is crashing. Let me know what it is, and I can proceed from there.
Cheers
Posted on Nov 10, 2008
What causes the blue screen and freezing?
The operating system is corrupted, this can be signs of a computer virus or malware.
Apr 05, 2012 | Dell Latitude D630 PC Notebook
I am getting an System Error of 0x1CDB when ever i turn on the system Error will remain same but the number or value changes but the background color will be blue
This colud be the Blue scree of death error we usualy call it BSOD....that is due to several reasons....here are some....
check and let me know if your facing such issues....
1) Failure of the compatibility of hardware and software 2) Running no of programs at a time : Blue Screen Physical Memory Dump Error is due to improper functioning of both hardware and software of your system. Even if you run more than two programs at a time then also your system may get prone to this error. 3) windows registry issues
Aug 02, 2011 | Computers & Internet
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
also you might download and use this registry cleaner it is totally free to use
hope this helps
don
Feb 23, 2011 | Computers & Internet
Keep getting a memory dump error
this problem only can fix by reinstall your computer operating system (windows)
Feb 22, 2011 | ASUS G51JXA1 PC Notebook
Blue screen physical memory dump?
This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
Jul 28, 2010 | Microsoft Windows XP Professional With...
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Memory dump
There are essentially two major causes of the physical memory dump screen: Running way to many programs at once, errors in the Windows registry.The first cause can be fixed rather easily. Simply run fewer programs or purchase additional RAM or processor upgrades. Your computer is running past its specified limits. But keep in mind the blue screen of
death should happen very infrequently. If you see the physical memory dump blue screen more often then the problem is errors in the Windows registry.This is a more abit of a harder problem to deal with. The registry is the most important component of your computer. The registry contains settings and information to run all software and hardware on the computers. When there are errors in the registry it disrupts the computers ability to communicate. When the system cannot compute, it freezes up and displays the Windows blue screen.
I found a registry cleaner that is free and works rather well. It is named cCleaner, has been around for some time and did I mention FREE...Download it from thelink below run it should clean up your registry...where good men fear to tread.
http://www.ccleaner.com/ccleaner-20
good luck, please leave a rating...thank you
May 04, 2009 | Intel Computers & Internet
Blue screen physical dump error
Hi
They virtual memory should have been exceeded the limit.
Step 1:
Power Drain:
1.Disconnect all the cabled from laptop, including Memory card and wireless card(wi-fi)
2.Take out the batteries
3.Press and hold the ON button for 30 seconds
4.Put the batteries in and boot the laptop.
if its does not works
Step 2:
Upgrade the RAM memory of the Laptop
Thanks
Riz
Jan 13, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Installation problem
Replace the hard drive with a new one. IT takes a standard IDE 2.6" laptop drive - I would try newegg.com they have pretty good prices probably about $100 for a 120gb drive.
The hard drive is under the 3x4" cover on the bottomn of the machine.
Dec 31, 2007 | HP Pavilion zd8000 Notebook
Gigabyte GA-8I915G Pro Motherboard Logo
77 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
