1.Insert your Windows installation CD into the media drive on your computer. Press the "Cancel" button when prompted to install the operating system.
2.Reboot your machine with the installation CD inserted into the drive. The computer boots using the CD into an installation screen. Press the "R" key to select the recovery console.
3.Press the "1" key to choose the Windows installation directory. The recovery console prompts you for the administrator password before continuing. Enter the password and press the "Enter" key.
4.Type "copy e:\i386\ntldr c:\" into the command prompt. Replace "e" with the drive letter for your CD-ROM and replace "c" with the drive letter for your Windows installation. For most users, the "c" drive is the typical location for the Windows installation.
5.Remove the CD from the drive and reboot your machine again. Since the NTLDR file is replaced with a clean version, the machine successfully boots to Windows.
Reset with f11?
SOURCE: acer aspire 3680
Start the Recovery Console
Boot the system to the Windows XP Recovery Console.
» Repair the Missing NTLDR or NTDETECT File
SOURCE: "NTLDR is missing" message on boot-up.
That message appears when Windows cannot boot. You may run a repair using your Windows CD. Just start your PC with the CD in the drive and follow the choices in the screen.Remember select REPAIR, not Install, as you will end loosing all your files.
SOURCE: Acer aspire one mini notebook. NTLDR is missing..
If you don't have documents, pictures,
etc on the hard drive that you need to backup, try running system
recovery by doing the following (not sure if this works on the version
with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
SOURCE: Boot Acer 3100 Aspire. Shows NTLDR is missing
Remove any 3.5" diskette from the A: drive.
Remove any CD from the CD/DVD drive.
Reboot.
If you still have the problem, then borrow a Windows XP disk.
Boot from it. Choose "repair", not "install".
If the disk-drive is "detected", then "repair" will attempt to fix any file-system errors.
If *NO* disk-drive is detected, your disk-drive has "died".
