Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I get unauthorized
Type in ip address 192.168.0.1, get dialog box, I type in admin with no password, but I get unauthorized.
  • somer1 Nov 10, 2008
    Unfortunately I've tried this, but it didn't help. I'm not sure what you mean by "commonly use password"
  • somer1 Nov 11, 2008
    I've reset the router, but still not working for 30 seconds, no luck; I tryed a static ip 192.168.0.88, 255 255 255 0, 192.168.0.1, dns 192.168.0.1 no luck. My computer is dell gx280, laptop is sony, still admin, no password =unauthorized :(
  • D-Link Master
  • 6,487 Answers
If the default password of the router is not working , try your commonly use password but if it still do not work you need to reset the router, to reset it Press and hold the reset button for 30 seconds while the power is ON then after that you can now use the default password of the router again...
Posted on Nov 10, 2008
  • Mark Gil
    Mark Gil Nov 10, 2008
    Anyone password that you use commonly like to your email becuase if you run the setup cd of the router it will be asking you for a password, but if its not working reset the router so it will be back to its default settings with the default username and password...
  • Mark Gil
    Mark Gil Nov 11, 2008
    Try clearing your browser settings like deleting the history, files and cookies and if possible try a different computer to access the router setup page....
How to change password to small
Open your preferred internet browser and enter "192.168.1.1" in your web browser's address field.
When login dialog box will appear,leave the user name field empty. Input "admin" in the password field. Click "OK" to log into the router. The blank user name and "admin" password are the default configuration settings for your router.
Click "Security". Type the new password you want to assign to the user account. Enter it again in the "Re-enter to Confirm" field. Click "Apply".
Close your internet browser after you have completed the password change to protect your router from unauthorized access.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 19, 2012 | Linksys Wireless-G WRT54G Router
Tip
How to add a password to a wireless router
To set a password on virtually any wireless router you can do the following: First, go to "Start" and "Run." Type in "cmd" without the quotes. When the Command Prompt comes up type in the following, without quotes: "ipconfig" Locate the box that says "IP Address" and remember that number. Go to your default internet browser and type in that number. (Note: If it does not work, when typing the "IP Address" in the internet browser, type the following, without quotes: "192.168.1.1" or "10.1.1.1") If a box comes up asking for the login and password, it is probably either blank or of the following: Username: admin Password: admin or Password: admin Now go to "Advanced Setup." Click on "WEP" and select "Enable" and choose either 64 bit or 128 bit encryption. Click the box called "Passphrase" and type in what you want the password to be. Click "Save Settings." Click on "WEP" again and remember what Key 1 is. (Note: This is important.) Now you can set all users to this. More information can be found here: http://www.iinet.net.au/support/wireless/guide/wireless_security.html
on Jan 02, 2010 | Computers & Internet
Dont remember password
password to your network?
well you can try accessing your router through your computer by plugging it in directly to your router with an ethernet cord. Once connected to your router. open a web browser and type in
192.168.1.1 or 192.168.0.1
one of the ip addresses should bring a dialog box up with a username and password field.
the user name can be
admin or user
password can be
admin or user or password.
try admin and admin first then admin and password then repeat with user.
once into your router you can go to wireless security settings and change your password in there.
Oct 18, 2012 | Computers & Internet
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
I have the wireless -G music bridge (model WMB54G) - I had forgotten the password so I reset it - Now, my computer will not recognize it - any suggestions?
The Linksys Wireless-G Music Bridge (WMB54G) has a web-based setup page that allows the user to customize settings and set up advanced properties.
Step 1:
Open a web browser.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
    • Running the WMB54G's setup CD.
    • Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
  • Press the Reset button underneath the antenna for 30 seconds.
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Feb 28, 2011 | Linksys Wireless-G Music Bridge (WMB54G)
Need ip address subnet mask number gateway number and dns server number
If the ip address you need is the Internet IP address, this is assigned by you service provider.
If you need an internal ip address, have a look in the modems configuration window.
This window is accessed using internet explorer and typing in the local address of the modem, usually this is 192.168.1.1 so enter this number. If this does not work, go to the modem manufacturers website and in the support section should be the manual (if you dont have one) and in the manual will be the ip address to access the modems configuration pages.
You must undertake these steps with your PC connected to the modem using a network cable, this will not work if you try this using a wireless link.
Usually, the admin and password details are admin admin. So type admin in the name section and admin in the password section.
Once you access the configuration area, navigate to the DHCP area and turn DHCP on.
DHCP stand for Dynamic Host Control Protocol. This simply gives an internal ip address to all the machines connected to the network.
Once this is done, save and reboot the modem and your PC.
Next,click on start and then run and enter CMD into the run dialog box.
When the text window opens, type in : ipconfig /all
dont forget the space between ipconfig and the / symbol
This will give you a list, in this list is the gateway ip address etc.
Usually, the DNS address is assigned automatically by your service provider but if not, you may have to contact them to get this number.
If you are trying to connect a second PC to the modem, all these details will be entered for you as long as you have "Obtain ip addresses automatically" ticked in the properties window of network connections. This is under the network connections applet in control panel. make sure everything is set to automatic.
Jan 13, 2011 | Arris SURFboard SB4200 Modem
Trying to setup wireless network need access to router
well, most routers operate on the ip address 192.168.1.1 by default, first thing, make sure your computer does not have a static ip address, but rather the ip is automatically, second thing is to open up your browser and type into the address bar 192.168.1.1, a dialog box should come up asking for your username and password, type in admin for both username as well as password, if this does not work just type in admin for password and leave the username blank, you should be greeted with a user friendly menu for setting the options fr your router, please do not change any option you do not understand, you might end up firewalling yourself out, if the first step does not help it might mean that settings have been customised already so you might have to reset the router, do this by looking on the back of the router, there should be a pin sized hole, just stick a pin down this hole and hold it down for about 5 to 10 seconds whilst the router is on, then start from step 1, Hope this helps...
Oct 25, 2010 | Linksys Wireless-N WRT150N Router
How do I put a password on my Belkin wireless G plus mimo router?
it depends on what you specifically want to password-protect: a. protecting the network from unauthorized users? b. protecting the network's admin interface?
for a. - log into your network's admin interface (usually http://192.168.0.1) - go to the category of wireless security - select the type of network protection you are looking for (strength - i.e. wep, wap, wpa2) and set your password following the steps listed within your router's admin interface...
for b. - log into your network's admin interface (usually http://192.168.0.1) - if you have never done this before, then your username should be filled in as Admin and leave password blank and hit enter.... from there, you are able to change or at least add a password to the interface from unauthorized access (usually under category security)
Feb 17, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Software problem
There is usually an IP address you have to type to get access to this hardware. Often you don't need the CD to install this hardware. The IP address is usually 192.168.0.1 for routers. Sometimes they differ. To find out if you go to start then run. When a box appears type in there cmd then press enter on your keyboard. This should bring you to DOS. Black page with white text. If you type into that box ipconfig and then press enter on your keyboard.The IP address you see net to the default gateway is your router address. Writed down those numbers and that box you are in just type the word exit and press enter on your keyboard and that box will disappear.Type that IP address into your address bar by opening up your browser. This will bring you to the hardware page of your router.You can do all the confguring from this page. Sometimes a box with user name and password appears. The username is usually admin and the password is either password, admin or these is no password so you just press enter on your keyboard and then when you're in start configuring. Run the setup wizard first before you do anything else. Then I would go to wireless and password protect your network. I usually password the router as well. This option is in the setup wizard you did earlier. Good luck
Jan 21, 2008 | Actiontec GT701AP (DNHGT701AP) 802.11b/g...
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
155 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
