Question about LG Televison & Video
TV recorder wont record from TV. All cables work and are plugged in
I think the system needs to be calibrated and then configured before the video can be used to record. It works fine otherwise.
    Sergeant:
  • 291 Answers
WHAT "" system needs to be calibrated and then configured ""........""It works fine otherwise""
Disconnect the VCR from anything. place a vhs tape with information [picture of something you don't want any more or a vhs tape that you want erased] in the machine. The tape at the back left TAB must be covered to promit recording. turn machine on,shub the tape in, press record. if after a time and you REWIND, and the begining is blanked of picture information...........the recorder [VHS] is working. looking to see the cables and how they are connected.
Posted on Nov 12, 2008
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I have a samsung dvd recorder, whats the proper way to connect for it to work, do i connect to cable box, tv
How you connect it depends on your system. You need to connect the video out of the recorder to the TV. If you want to record programs, you need to connect the cable box to the recorder's video in. (The unit doesn't have a tuner if you have the unit listed above.)
Place the IR Blaster near the set-top box IR receiver. Connect the RF cable from the wall to your set-top box and then another RF cable from the set-top box to the TV (not to the DVD recorder). Connect a composite A/V cable from the set-top box A/V (composite) out to the DVD recorder's A/V in (AV1) port. (Composite video is a three wire cable - the plugs are yellow (video) and red/white (R/L audio).)
Next you need to connect the unit to the TV. Depending on the TV, you can use an HDMI cable (best results), component video or another composite video cable (labeled AV2 AV out). If you use component video, you'll need a separate cable to carry the audio. (Component video cables have 3 RCA jacks on each end (red, blue and green). The audio cable has the red and white plugs.
You will only get a 480 (SD) signal output if you use anything other than the HDMI cable. (The progressive scan feature is not compatible with all TVs; see the manual for details.)
You can obtain the manual from http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=DVD-VR375 .
I hope this helps.
(you have an additional A/V IN connection as well as a DV In port on the front of the unit)
Sep 12, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Cant record audio
you need to select the audio input device as internal stereo mix.
Aug 11, 2009 | Gateway D-Link DI-604 Cable/DSL Router...
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
My sanyo vcr won't record, but can play.
Hello nrj9,
When you upgraded your cable box you changed the dynamics of your system. Try this.
Connect the coax from the wall to your cable box, then connect the HDMI cable (if you have this) from your cable box to your TV and the component video out connection from the cable box to your component video input of the VCR and then your VCR component video out to your TV's component video in.
What this will allow you to do is:
Using the TV chose between the VCR and the cable box for video,
using the VCR record from the cable box.
There are other configurations, but this one is the best for what I think you want to do.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 10, 2008 | Televison & Video
Record a digital channel while watching and analog channel
Take a red, white, and yellow AV cable and plug it from the AV out of the cable box to the red, white, and yellow In of the dvd recorder (change cable box to the channel you want to record). Then change your TV to the channel you want to view.
Have fun!
-Tha Mp3 Doctor
Nov 23, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
Sep 27, 2008 | Televison & Video
WinFast PVR2000 - recorded video has no sound
check the software configuration for the tv card to see if it using the correct audio device
Feb 24, 2008 | Leadtek Winfast PVR 2000 (663001C) Video...
Sound not recorded
You need an 1/8" male jack plug (both ends) cable. One end plugs to audio out on TV card, the other end plugs to audio in on the sound card. Or is it the other way around. Anyway, thats what you need. I think Radio Shack sells them maybe BestBuy or Circuit City.
Jul 02, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Televison & Video Logo
61 people viewed this question
Computer Repairing
Computer Repairing
