Question about Linksys Wireless-G Range Expander (WRE54G)
Ok so I have a wireless adapter and I recently lost the password for it I was wondering if you had anyway to reset it or find it. I know it was just a bunch of letters and numbers nothing I set up.
  • 689 Answers
The password you are referring might be WEP or WPA which assigned by your router. So you need to reset your router not the Wireless adapter. After you reset the router's Network Key (WPA/WEP)
You can reset your Range extender too; Press the Reset button on the back of the Range Expander for about ten seconds. This will reset the unit to its
default settings
Good Luck
Posted on Nov 10, 2008
I lost my net gear n150 cd and i want to change my password..
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
Sep 10, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Can access internet to my laptop via ethernet cable but not wifi through Cisco Linksys router model no SPA2102 as I have lost network security code... tried to find number to call for support but dont...
ok well if you lost your security code then the only way you can connect to your wireless connections again is to have the correct credentials correct Passwords .in your case you lost your Password the only options you have is to reset your router and setup new Password for your wireless . ok lets reset the wireless router now . on the back of your router their is a tiny hole says Reset use needle or a pen to press the button for 40 seconds and release turn off your wireless from the plug and turn it on again . now connect to your wireless and you will not need password to connect Internet.
if you need help with setting up password on your router then email me zana_adil86@hotmail.com
May 02, 2011 | Computers & Internet
I forgot my password and want to know my password
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don't forget to vote
Feb 27, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Ive recently changed the password on my wireless network and now my printer keeps flashing orange which means it wont connect to the wireless. From reading a similar post i saw you recommeded to reset the...
To reset the printer's wireless network adapter:
  1. Press Setup(wrench icon).
  2. Go to Network Setup, press OK.
  3. Go to Reset Network Adapter, press OK.
WiFi light will temporarily turn off then will turn on solid orange. Now, run the printer's Wireless Setup Utility on your computer to configure the printer with the new wireless settings. You will need the USB cable temporarily to successfully configure the printer. Thank you for choosing Lexmark.
Sep 10, 2010 | Lexmark X4650 InkJet Printer
No manual - lost password
You will need to reset the router so that you can get in. Unplug the router. Press the reset button with a paper clip while inserting the power. Hold the reset button for about ten seconds.
The modem should be reset to defaults: admin/admin (as user and password) and the gateway address should be 192.168.1.1.
From a hardwired PC, you should be able to point your browser at 192.168.1.1 to reset the password of the router and the network key.
May 23, 2010 | Linksys (WIFIDESKTOP) Wireless Adapter
I forgot my password for belkin f5d7231-4
Do you mean the password for the wireless network or the password for the router. If you don't know the wireless network key or the password then you will need to access the router set up and you will find the wireless password there. If you don't know the password to access the router then you will need to reset the router and reconfigure the router. Click Here for step by step solutions
Nov 16, 2009 | Belkin (F5D7230-4) Router (587009)
Reset password for senao unit
pci adapter don't have password password have in the router or modem or access point device
Apr 07, 2009 | SENAO NMP-8602 (NMP8602) Wireless Adapter
Computer crashed, reset to factory, lost info for linksys adaptor
If you download them to the desktop of the laptop and burn to cd or copy to flash then you may have something going. See if they will d/l to desktop from linksys site.
Mar 15, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Aspire 5050 network adaptor not found ??
ok, the problem is that your wireless adapter of your notebook has not been installed yet. locate the cd that comes with your notebook and install the wireless adapter.
Dec 22, 2008 | Acer Aspire 5050-3242 Notebook
Westell 327W15-06 Modem/router password doesn't work- can we reset?
It's either admin/password or admin/1234. Reset the router to factory specs by holding in the reset tab for thirty seconds.
Aug 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Linksys Wireless-G Range Expander (WRE54G) Logo
202 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
