Question about Samsung HCM4216W 42" Rear Projection Television
RED lamp flakey
Yesterday my HCM4216w started to lose the Red lamp. It seems to some and go. But goes more. Please help I can't seem to find a local reair shop willing to come and fix. or even look. I am skilled in electonic repair just never tackled anything like this Samsung HCM4216w Manufactred June 2002 Thanks Mark
Better late than never I guess. Thanks I completed this repair a year ago with out any problems.
Mark
Posted on Dec 10, 2007
  • 934 Answers
Mark,
When you say skilled I'd STRONGLY suggest be a CET or better to tackle this job or I'd give you a one-in-a-thousand chance of doing it successfully... That said, it's pretty straight forward - the unit has to be torn down to light box level and the crt removed... After disassembly of the coolant chamber from the crt it is recommended by Samsung to install the coolant overflow kit, Samsung bullentin tip # 20040827001. P/N: Aa91-00607a / Bp96-00645a
If on the other hand you want some help finding a good qualified shop try here: http://www.nesda.com/locator/state_search.php
Bill
Glow light goes off then comes back on but had new plugs fitted?? Laguna 51reg 1.9dci
The repair shop has to diagnose the problem
& find something, obviously
May need a different place
The Malfunction Indicator Lamp is not the problem
It will be on until the vehicle is repaired
Jun 26, 2012 | Cars & Trucks
Benq pe8720 service manual
8720 Went out just prior to playing. Now will start up, go to benq logo then lamp goes off. on top of projector lamp light is red. repeat lamp does go on seems as bright as ever but shortly after benq logo goes off. By my recollection lamp is not beyond it's 2000 hour range.
Feb 18, 2012 | BenQ PE8720 DLP Projector
I replaced the bulb on my optoma ep1691 projector but the picture still goes out and the red lamp light lights up. I reset and confirmed the reset via the menu. How can I resolve this issue?
It seems OEM lamp that was replaced in projector is not good, please return this lamp and ask another lamp to solve projector problem. Projector seems fine and has no issue, it is replacement low priced lamp that is causing problem.
I would recommend to buy original lamp from Optoma Support.
Thanks.
Mar 02, 2011 | Televison & Video
I have a HCM4216W rear projection tv. It was
The convergence IC have gone bad, bad solder connections to IC or probably both. The board as a whole can be purchased as complete (look to the web to find where to get) and is fairly easy to replace. Unless you have extensive experience with component level repair I would suggest you take the board to a TV shop to repair. This option maybe slightly less then replacing board. Check with your local TV repair shop to see which option is the best in your area.
May 06, 2010 | Samsung HCM4215W 42" Rear Projection...
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Red horizontal lines
Misaligned red lines in your TV is due to failure of Convergence Out ICs and requires replacement.
Let me know if you are familiar with TV repair to provide you part number info OR call local TV tech to fix the TV.
Thanks.
Apr 18, 2009 | JVC AV-48WP30 48" Rear Projection...
Sound no picture?
I have no solution for this problem and I'm not sure I can fix it without taking it to a repair shop. The replies I got yesterday did not help.
Jul 30, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Mar 17, 2008 | NEC LT30 Multimedia Projector
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Samsung HCM4216W 42" Rear Projection Television Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
