Question about Kyocera Office Equipment & Supplies
Kyocera FS 1000 - paper wrapped round hot roller
    Scholar:
  • 121 Answers
The hot roller unit is the fusser unit
Its main purpose is to stick the image toner to the paper with heat
try removing the unit when its cool
remove th paper slowly by turning the gears slowly.....give extra care not to damage the Teflon
wipe the Teflon of with alcohol to remove stains of paper....dry the alcohol properly
put everything back and u are ready to print...
if the Teflon is damaged ull need to replace this unit......
Caution.......dry the alcohol properly as this could result to fire......monitor print outs printer for the first 10 to 15 prints as to verify that everything is k....
Posted on Nov 10, 2008
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
May 28, 2010 | Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera fs-1920 paper jams when page is half way out of top , when you clear it the paper has some grooves in ? does not happen every time and when cleared it is ok again for 3-6 pages
on the menu buttons on the machine..change the paper exit to go out the back.. if this solves the problem.. you might be looking into replacing exit rollers or fuser
Mar 09, 2010 | Kyocera Mita FS-1920 Laser Printer
Paper jammed between 2 red rollers in the back, can;t dislodge
The red rollers are probably replaceable, and therefore removable. Take a close look, and see if you can tell how they would be removed. It will either snap out, or you'll push it to the side and remove one end at a time. It'll be easier to pull the paper without the roller in the way.
While you have the roller out, you can clean it by wrapping packing tape around it a few times.
Jan 03, 2010 | Kyocera Mita FS-1920 Laser Printer
Hi there i have fs kyocera 1000 and when i wont to print the printer tak the paper but the paper get empty and the printer stop .so i open the cover and close the printer resuom printing and the paper get...
clean the paper feed roller with a damp cloth after removing the paper tray, otherwise call a technician since parts may need to be replaced, including the roller in case.
Feb 26, 2009 | Kyocera Mita FS 1000+N Laser Printer
Kyocera FS2000 thin black vertical line on RHS of paper??
first try cleaning the charge roller on the drum unit or check the hot roller on the fuser
Dec 05, 2008 | Kyocera FS-2000D Laser Printer
Printing Issue
sounds like it got hit by lightning and needs some serious repair... consult a service technician... in your area
Jun 03, 2008 | Kyocera Mita FS 1000+N Laser Printer
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
138 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
