Question about Archos AV 500 400-Hours Video Recorder
Archos AV 500
I have a similar situation, my Archos when I try and turn it on the blue splash screen comes on the HDD light flickers and it sounds like the HDD turns then it turns off. The Screen stays on if it is charging, but nothing more. Also the screen will stay on if the power button is held down. When it is attached to the computer and is switched on windows says the USB device attatched has malfunctioned. Any Ideas....???? I'm lost r.whitestone@gmail.com 07966422994 01939 235371
SOURCE:
  • 3 Answers
SOURCE: av 400 - will not turn on
Mine did that too, and I was freaking out. I don't know if it will work for you, but I took the battery out for hours, maybe 4 or 5 hours. I went to show someone what it was doing, put the battery back in and it worked. It is still freezing when I play music more than it was, but I got my data off at least.
Posted on Feb 22, 2007
  • 758 Answers
SOURCE: help
http://www.archos.com/support/download/firmware.html?country=global&lang=en
Posted on Jan 17, 2008
  • 3 Answers
SOURCE: archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
Posted on Jan 31, 2008
Yazz226
  • 497 Answers
SOURCE: Archos Av500 startup problems
its a HDD or OS failure
ull have to ask the company for a replacement if its under the warranty period
make sure to register ur device on the Archos website to get a 'Technical Support Passcode.'call Archos to tell them ur problem and if ur lucky they wud repair it free of charge
if u want to try it urself...i found this one of the forums on the net..
1.remove all the screws, and remove the battery.
2. Remove the hard disk from the player by disconnecting the ribbon connector carefully from the mainboard.
3. Try to startup the player after putting the battery back in place. This time, instead of turning off, the player showed a "cannot read hard disk" error with the option of formatting it. Made me realise that the hard disk was the culprit. However, I had heard the hard disk noises previously, and they sounded fine, so I realised it was a software issue (file system was corrupted)
4. Try to connect it back, same problem as before... Also it is very difficult to first start the player & then connect the hard disk, as the player is designed to shut off in that situation.
5. The best option after this would be to get a drive enclosure designed specifically for 1.8 hitachi hard disks to connect the disk directly to the computer using USB and format it.
6. However since I didn't have a specialised enclosure, I did a lot of trail and error with the player itself (running off mains while connecting the hard disk after starting the player without releasing the power button etc etc etc) which Im sure wasnt too kind on the hard disk, but voila, I managed to start it up fine WITH the hard disk in place without the player turning off using some weird combination of holding down the power button and connecting the ribbon on the bootup screen)
7. After this, he was able to select "format", and the player began working fine he lost all the data on the player itself, but luckily he had backups of everything!
Thanks for using Fixya
Posted on Jul 16, 2008
  • 6 Answers
SOURCE: Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Posted on Jan 20, 2009
Not Solved 9/17/18 A 9 yr old 55 LG LCD tv I need help with. Model 55LH55-UA w/ black screen exhibiting the following: -turning on tv by remote or on the side, blue ON light comes on, screen is black.
Sounds like you have LED backlights that are going bad and the strips need replacing, its not a real easy job but if you watch some youtube vids they show how to do it.
Sep 16, 2018 | LG Televison & Video
Jul 16, 2008 | Archos AV 500 400-Hours Video Recorder
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
Jan 12, 2010 | Archos Internet Media Tablet MP3 Player
Archos 5 won't boot up
im having the same problem,people say reset it and put it into recovery mode (it tells you in the quick start guide) or that didnt work for me so im trying charging it up fully.  also mine makes a noise while trying to turn on, are you having this problem to?
Jun 28, 2009 | Archos AV 500 Digital Media Player
Charging problems
I've got the same problem. The only solution I have come up with is to purchase an external battery charger.
Mar 10, 2008 | Archos AV 500 Digital Media Player
Archos gemini av 500
Is the drive recognised by your PC when you plug the Archos into the computer?
Mar 02, 2007 | Archos AV 500 400-Hours Video Recorder
Av 400 - will not turn on
Hi, my archos does the exact same thing, however, when I press on, it turns on, then I hear a "click" and it turns itself off. Only when I have the charger plug in does the archos logo continue to remain on the screen. Did you find out what our problem is?
Dec 22, 2006 | Archos AV 500 400-Hours Video Recorder
Archos AV 500 400-Hours Video Recorder Logo
46 people viewed this question
Top Archos Televison & Video Experts
Inky Fingers
Inky Fingers
Jaime Hernandez
Steve Sweetleaf
Steve Sweetleaf
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
